Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Tube bender question
Old 01-03-2019, 10:39 AM   #1
Default Tube bender question
Using bearings is kinking the tubing....
awoodman is offline   Reply With Quote
Old 01-03-2019, 03:07 PM   #2
CODYBOY's Avatar
Default Re: Tube bender question
That brake line you have may have to thin of a wall to get that tight of a bend with out linking. Having said that, this is my DIY bender.
This is how I keep most of my bends from kinking.
I use a heavy flat washer, a 1/8" spacer, or 1/4" spacer depending on the size of the tubing I'm bending. The spacer should be the same size as the tubing you want to bend.
I turned a hardened socket head bolt down until I have a very thin lip to hold the washer tight...
Hope that helps you out a little. Let me know if I can help you any more!
Ernie
CODYBOY is offline   Reply With Quote
Old 01-04-2019, 09:54 AM   #3
I see, the tube must be kept from expanding upward....and a coved inside die isn't necessary....
Old 01-17-2019, 12:35 PM   #4
I havent tried tubing myself but was given this advice:
Originally Posted by JRDV View Post
If you try tubing, fill it with sand and plug the ends.
Its what I do on 1to1 tubing when I use my pipe bender.
John
HumboldtEF is offline   Reply With Quote
Tube bender question - Similar Threads
my tube bender........... bob1961 Tools, and Procedures 109 04-11-2020 05:36 AM
tube bender timmy85 Tools, and Procedures 17 02-20-2010 04:58 PM
Tube Bender Question rcr3fan29 Tools, and Procedures 3 02-08-2006 01:20 PM
