05-19-2007, 12:46 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: SLC
| Composite parts made easy
Here is a fun project. Using pink foam and gypsum casting plaster you can make a wide varity of parts. I searched the local phone book and found casting plaster at an art supply store. 90lbs. $30.00. You should get 2 5gallon containers to keep it in. It comes in a bag like cement and can be messy without the plastic containers. You can get Pink foam from Home Depot, pink is the harder stuff most blue foam is soft. A small hot wire tool is very usefull. So you will be out about 50.00 and have enough stuff to last years. MikeP |
05-19-2007, 12:50 PM | #2 |
Make the part you want out of foam.
05-19-2007, 12:55 PM | #3 |
Slice up some foam for a box to make a mold in. I use 3M77 spray glue to assemble everthing.
05-19-2007, 01:04 PM | #4 |
Fillerup with plaster, pounding the table will release any air pockets as you fill the box. This one took 3 batches to fill. Try to make the top flat as that will be the bottom of the mold.
05-19-2007, 01:09 PM | #5 |
While the plaster is still "green" is a good time to clean it up. I use a good wood chisel to clean the edges and well used 80 grit to smooth out the foam texture left in the finish. The mold needs to dry out for a couple days before continuing. |
05-19-2007, 01:17 PM | #6 |
The mold needs to be sealed with epoxy, you can spend as much time as you want to get that perfect finish in the mold.
05-19-2007, 01:20 PM | #7 |
Wax the mold and lay it up.
05-19-2007, 01:26 PM | #8 |
Some shots of the finished part with just a litte triming left for final fit.
05-19-2007, 01:34 PM | #9 |
What kind of wax do you use?
05-19-2007, 01:35 PM | #10 |
Now, I really want a red rig. So I mixed up some epoxy, added red automotive paint and used it for a gel coat. That way any deep rock rash will not remove color as it will be solid red.
05-19-2007, 01:42 PM | #11 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
05-19-2007, 01:51 PM | #12 |
Here are some pics of supplies I use. Partall mold release wax West systems products Brushes and alcohol to clean brushes |
05-19-2007, 02:02 PM | #13 |
A shot of the home made oven. Its made from foil coverd insulation, 2 light bulbs a light dimmer switch and a digital thermometer. At WOT it will do 160 deg. I will be able to pull the new red parts later tonight instead of tomorrow. About a 1/2 hour at 80 deg. until its good and firm then 100-120 for a couple hours. |
05-19-2007, 02:18 PM | #14 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
Great how to Mike I have used old fashioned turtle wax in a pinch. It does work, just not as smooth as real mold release. Also Chalk is another good option for coloring your epoxy. I buy the clored chalk for chalk lines. |
05-29-2007, 05:49 PM | #15 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
That is cool. I might have to hit up the local TAP Plastics to see what I can find. Mike - Can you post up some pics of the red parts you made? I'm curious how those came out. |
05-31-2007, 08:08 AM | #16 |
Will have some pic's soon. I will do a build thread on this new rig. Due to the untimely death of my best friend and long time RC buddy, my motivation is low. Mike |
05-31-2007, 08:24 AM | #17 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
My condolences on your buddy. Just get back on the hobby wagon, as I am sure your friend would have wanted you to. Build it as a tribute! |
06-07-2007, 12:25 AM | #18 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Gotta follow this thread. Great work Mike. |
07-02-2007, 12:26 AM | #19 |
Howdy, Here are the red parts. |
07-20-2007, 07:21 PM | #20 |
Newbie Join Date: May 2007 Location: buffalo
how do u get the carbon fiber to hold the shape of the mold? sorry im a newbie |
