Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Help on Flux
Old 12-06-2007, 04:55 PM   #1
toy4crawlin's Avatar
Default Help on Flux
My flux ( harris safety x?x?) is watery milky on the surface and below is very solid.
I tried mixing together a bit but when apply on material and apply heat it burns on like a crust
What am I doing wrong?
I have watched videos of brazing and read Jay's brazing intructions, it looks like it should be so simple. when I silver solder is it a peice of cake.
Thanks
toy4crawlin is offline   Reply With Quote
Old 12-06-2007, 05:17 PM   #2
My personal experience, the flux dries out over time if it sits. I add some water and mix it up real good and it's as smooth as butter, goes on good and burns good...maybe try the water.
joemomma95 is offline   Reply With Quote
Old 12-10-2007, 05:39 PM   #3
Thanks
That's actually normal really. when heated it burns off all the contaminents. Some joints will be redish in color and hard, but it'll come off. Other joints will just turn whiteish. sometimes there is too much water and sometimes it's to dry but it'll still work the same.
I also try to use bottled water when liquifing the dried flux.
Double J is offline   Reply With Quote
Old 12-10-2007, 05:59 PM   #4
what brand?
my joints sometimes have a white crust on them once they cool. quick wire wheel or a brillo pad and all is normal again.
one small can of flux should last you about 12-15 t.o. of braze. stuff lasts forever.
mrpink is offline   Reply With Quote
Old 12-10-2007, 06:28 PM   #5
[quote=mrpink;958146]what brand?
[quote]
The expensive kinds..
Arrow head.
Store labeled brand. You know the good stuff.
Old 12-10-2007, 09:15 PM   #6
Try it without flux.
Honestly, try it.
Robb is offline   Reply With Quote
Old 12-11-2007, 08:04 AM   #7
trying to braze alu again ?
Not many had succes so why dont braze up a steel tuber, they dont wheig much either
crawl rookie is offline   Reply With Quote
Old 12-11-2007, 01:30 PM   #8
it's my first so I thought I would try aluminum, but if the new braze rod the shop gave for free does not work then I'll go steel
Old 12-12-2007, 07:17 AM   #9
thats not nice
I'll wish you luck! on brazing alu.
Ask mrpink about the harris stuff.
He made a d-trial chasiss a 11inch i thought and those are made out of thick alu!
