Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Brakeline coating
Old 01-06-2008, 05:16 PM   #1
Default Brakeline coating
I got some break line tonight and it has this thick grey coating on it. Is this the coating I have to sad off or is it different. It is steel but you cant even see the steel it almost looks like it was powder coated. I may be able to get pics of it tomorrow
NoblesvilleKid is offline   Reply With Quote
Old 01-06-2008, 05:42 PM   #2
Location: Ramstein Air Base Germany ...ya Ive been Ramshafted
Its probably been Galvanized and yes run some light sand paper over it before you try to do anything with it. Also wear a mask the fumes are highly toxic when its heated or sanded. The only other wierd style of brake line I know of is a very dark brown collor so hopefully I was able to help
CCFBERG is offline   Reply With Quote
Old 01-06-2008, 05:44 PM   #3
How thick are we talking here? to the point that it looks like its been dipped in something? or like its been sprayed with ceramic paint?
Old 01-06-2008, 05:46 PM   #4
It looks like its been sprayed with ceramic paint. It is kind of like the dark grey color of RCC's background. I wasn't sure because all the tube I see on here looks like bare metal
Old 01-06-2008, 05:59 PM   #5
Here is a pic of it (sorry it is kind of blurry)
The brand is PolyArmour. The lines are where I started to cut it
Old 01-06-2008, 06:41 PM   #6
thats what they sell at autozone.... Its kind of a pain to work with. I much prefer the regular brake line from napa.
Calderwood is offline   Reply With Quote
Old 01-06-2008, 06:42 PM   #7
Would it be worth my time and money to just go to Napa
Old 01-06-2008, 07:03 PM   #8
MWRCA'er
Mnster's Avatar
Yes, it would.
I've been faced with the same problem before.
Mnster is offline   Reply With Quote
Old 01-06-2008, 07:19 PM   #9
A company called AGS makes the brake line most of us use. I find it at Pep Boys (large auto parts store) it runs about $6 for a 60" piece. No coating.
p!nK
mrpink is offline   Reply With Quote
Old 01-06-2008, 07:25 PM   #10
Nice to know that there's brake line out there that doesn't have a coating on it....sanding every joint sucks. Why doesn't anyone tell me these things....
joemomma95 is offline   Reply With Quote
Old 01-06-2008, 07:25 PM   #11
Thanks everyone for the help, I will probably be able to go to Napa or Pep Boys sometime this week they are both about 2 minutes from my house
Old 01-06-2008, 08:51 PM   #12
yea get some other stuff....
if that's the stuff I think it is,with 1:1's it works nice bends super easy and dos'nt kink easy....
dhoffroad is offline   Reply With Quote
Old 01-07-2008, 06:39 AM   #13
Yep thats what they call "bendable brake line" was just looking at that stuff the other day. Supposedly that stuff has a high ending tolerance meaning you can bend it by hand and it wont buckle. Dont quote me on that but thats the way its been explained to me. I would go get yourself some good old fashion Brake line, it will most likely be Galvanized but thats just to keep it from rusting.
Old 01-07-2008, 08:02 AM   #14
I have some of that. If you bend it wrong, you can bend it back pretty easy without it buckling.
I'll head to Napa to get the other stuff next time!
Racer4Life is offline   Reply With Quote
Old 01-07-2008, 08:39 AM   #15
When I go to get the new brake line what color should it be
Old 01-07-2008, 12:34 PM   #16
[HOONIGAN]
Wrecker's Avatar
The stuff at napa needs to be sanded too!
It's a much tinner galvanized coating but it needs to be removed. It's toxic to burn that stuff and it makes your joint look like crap cause it will start to crackle and discolor and stuff. Also, silver solder will not stick to it at all, but the cheap brass brazing rod does. I just use a 4.5" angle grinder with a flap disc and sand off all of the coating on all tubes of the joint.
Wrecker is offline   Reply With Quote
Old 01-07-2008, 12:53 PM   #17
I have used both and the type with that thicker coating doesn't braze as well. I sand the whole thing down but the coating must bond pretty good with it because it still doesn't braze as well.
As far as sanding, I usually just get a piece of sand paper and sand the entire piece of brake line before I start cutting. Makes it easier then just sanding the ends before you braze.
TxCruzr is offline   Reply With Quote
Old 01-07-2008, 02:28 PM   #18
Does anyone get there tubing at Advanced Auto Parts or CarQuest
Old 01-07-2008, 05:16 PM   #19
haha i just us it anyways, dont inhale the fumes though, never had a problem with it but the paint does burn and bubble a bit
TurnThePage is offline   Reply With Quote
Old 01-07-2008, 05:54 PM   #20
Yes, I always used the AAP line, both the straight lengths and the 25ft rolls. Stuff is great to work with.
Oh and about the galvanized coating, after working with it, drink milk. My dad is a welder and where he works I guess thats what they tell you to do after breathing in the fumes or even just handling the galv. coating.
'83 chevy is offline   Reply With Quote
