06-14-2008, 01:38 PM | #1 |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
| UE SuperMaxx Diff Locker
Picked up some UE Supermaxx 6 spider gear diffs for the Super. Some kind of theme going on here?? Thats right. BEEF. Wondering if there are any type of spool or locker for these or if I have to build one. Looked on the bay and did not find ANYthing Same as OFNA 1/8th scale buggy diffs. What is your opinion on flooding the spider gears with solder to lock them? Being 6 spiders, I'm sure there is plenty of teeth to catch with even just epoxy but I would think some hot lead would hold even better. WC |
06-14-2008, 01:45 PM | #2 |
RCC Addict Join Date: Mar 2006 Location: Xxx
Waste of your money. Should of locked it with JB and called it a day. Or buy the tmaxx spool. I had the 8 spiders in a race maxx and only way to find replacement parts is to shop ebay. UE = paper weight. |
06-14-2008, 01:54 PM | #3 | |
The maxx spool will need to be adapted to the ring gear though right? No problem. The bearings are a different size are they not???? Paper Weight?? Excuse me? Please explain. From what I have heard these things rock! WC Last edited by WheelChair; 06-14-2008 at 01:58 PM. | |
06-14-2008, 06:06 PM | #4 |
A spool from a Force axle should work, Yotachump on here makes them out of durable material. UE does not = paperweight, IMO it's the best stuff out there. All the parts are OFNA, and you can still get the gears, but why? |
06-14-2008, 06:12 PM | #5 |
Thread about Yotachumps spools: **Twin force/ Mad force spools are here** |
06-14-2008, 06:12 PM | #6 |
| I've been abusing chumps spools for a good while now. VERY nice piece. Stripped a helical cut ring gear but the spool is still like new. |
06-15-2008, 01:21 PM | #7 | |
So are the helical gears the four to one ratio ones? part #?? I know the UE comes with a 3.30 (??) gearset, are they stronger? I'm going to order up them spools today, they appear to be very high quality. Thanks for the recommendation! With a 4 to 1 gearset, I bet I could mount the 3032 direct on the tranny without gear reduction. WC | |
06-15-2008, 10:03 PM | #8 | ||
The helicals are stronger than straight cut gears simply cause theres more tooth contact. You'll have to shim them up right,so get a few packs of shims. Quote:
If I were to guess,somewhere around 75:1 final would be a good place to start. You can then gear up or down a little to find the sweet spot. | ||
