Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Traxxas Crawlers
Thread: Traxxas long travel kit
Old 03-20-2019, 07:49 AM   #21
Moderator
JatoTheRipper's Avatar
Default Re: Traxxas long travel kit
Originally Posted by ryanwkennedy View Post
You may be right. But my theory is that if you can keep the COG down, in addition to the unsprung brass weight i have as well as two stage foams, that the flex will ultimately help. Im never going to do comps or step sidehills, i just want to not get hung up in the rocks out playing. I thought about doing adjustable shock mounts as well to lower the height.
Originally Posted by mass-hole View Post
To much flex or too much height? I am trying to do similar but keep the truck at the stock height via the use of taller shock towers(Hot Racing or the eBay knockoffs.) You can run a 20mm longer shock, which has 10mm more compressed length, and still be at the factory ride height and bottom out in the the same position as the stock shocks.
You pick up 10mm of travel without hurting COG or anything else.
Too much flex for sure. With too much flex the truck wants to rollover in situations where it wouldn't if flex was limited.
Obviously the taller height is going to hurt it in situations as well, but you gain ground clearance at the chassis.
Old 03-21-2019, 02:33 AM   #22
Originally Posted by rcreview View Post
Lift kit was not what I wanted so converted it to a long travel kit
How about posting a flex pic with the body actually mounted on the chassis instead of sitting on it all crooked and cross eyed?
MentalGuru is offline   Reply With Quote
Old 03-21-2019, 03:18 PM   #23
Lolz, and with the rear tire touching?
mass-hole is offline   Reply With Quote
Old 03-21-2019, 06:10 PM   #24
Agreed. Fake flex!
Inspector86 is offline   Reply With Quote
Old 03-21-2019, 07:16 PM   #25
Originally Posted by Inspector86 View Post
Agreed. Fake flex!
Like
Old 03-22-2019, 04:47 AM   #26
Maybe it is obvious but: what bike is that in the background?
Anyway, I like the idea of turning the lift-kit into a flex-kit
Stollenritter is offline   Reply With Quote
Old 03-22-2019, 09:31 AM   #27
looks like an electric Pivot. So basically one that costs more than my 1:1 Jeep.
Old 03-24-2019, 08:59 AM   #28
Thanks for the info on the bike
Old 03-31-2019, 03:01 PM   #29
Correct, Pivot Shuttle for $10k.
Modded now so much pricier
rcreview is offline   Reply With Quote
Old 04-01-2019, 09:21 AM   #30
I'd like a Pivot, but I got such a good deal on my Intense Carbine 29C I couldn't pass it up. Fun bike for sure and it will run anything over like its not there.
Traxxas long travel kit - Similar Threads
Steering bind after installing Traxxas long arm lift kit. Help! Foxtrot121 Traxxas TRX-4 13 07-31-2018 09:55 PM
In Stock - NEW Traxxas TRX-4 Long Arm Lift Kit RPP Hobby RPP Hobby 0 06-05-2018 02:16 PM
Coming Soon - NEW Traxxas TRX-4 Long Arm Lift Kit RPP Hobby RPP Hobby 3 06-04-2018 01:49 PM
long travel shock's Cork 2.2 Scale Rigs 6 09-21-2014 05:57 PM
Long travel shocks f/r? xLPlushy Axial Wraith 21 05-27-2012 01:33 PM
