![]() | #21 |
Newbie Join Date: Jan 2013 Location: PARKER
I downloaded the manual before I even got the TRX. I copied it to a flash drive, took it to my local printer and had it printed, bound and a clear cover put on it. It was expensive because I did it in color. Cost about $25.00. You could print it in b&w for about half that. Or print it on your printer and staple it. Seems everything I buy from refrigerators to Rc cars, you have to download the manual. Just another cost in buying stuff.
![]() | #22 | |
| ![]() Quote:
![]() ![]() ![]() [QUOTE=BRICK57;5716159]I downloaded the manual before I even got the TRX. I copied it to a flash drive, took it to my local printer and had it printed, bound and a clear cover put on it. It was expensive because I did it in color. Cost about $25.00. You could print it in b&w for about half that. Or print it on your printer and staple it. /QUOTE] Good idea, but I download it to phone for keeping while crawling and print out double-sided and staple it together myself, $25 isn't bad for color bound and clear cover. ![]() Truck drives smooth and very predictable even on sidehill and steep climb. | |
![]() | #23 |
RCC Addict Join Date: Jan 2007 Location: Las Vegas
I only have a couple hours on mine but here is my take so far: Stock tires are pretty good. The foams are a bit stiff but will soften up over time and be right. They are pretty sticky. Shocks seem smooth, but two of mine came low on fluid. The springs are too firm. The drivetrain is extremely quiet and smooth. The diffs lock quickly and smoothly. I'll probably ditch the two speed once someone comes out with a kit. Hopefully they get a gear ratio somewhere between high and low. Turning with both diffs unlocked is awesome and for that reason alone I'll probably not permanently lock them. The stock steering servo is a bit weak, but that's typical for an RTR. The body is great looking. The way they integrated the fender wells and different supports/mounts on the body is great. It doesn't vibrate or wobble. All the details are very nice for a lexan body, unfortunately it is heavy and huge, which hinders performance. |
![]() | #24 | |
RCC Addict Join Date: Sep 2014 Location: Alberta
| ![]() Quote:
![]() | #25 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| ![]() Quote:
![]() Would it be easy? No. ![]() All depends on the work you want to put in. I would imagine the aftermarket would be building any bodies to actually fit the existing liners as best they can due to what they provide. The liners really strengthen the heck out of the body and keep it stable and rattle free. It feels like a hardbody, but the actual shell is a normal thin lexan due to all that bracing provided. | |
![]() | #26 |
I am a Chevy guy thru and thru so the Land Rover body doesn't do it for me. Gotta get a different body on this thing when I get mine. Sent from my iPhone using Tapatalk |
![]() | #27 | |
| ![]() Quote:
I have seen people using the Vaterra GM SUV already though. Even some using the SCX10.2 Cherokee. | |
![]() | #28 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Pretty much agree with everyone else. Great truck, steering servo's *meh*, top heavy... I really like the tires, and I spent money that wasn't really in my RC budget to get it, so I'll probably just bake them off and get some inexpensive beadlocks... |
![]() | #29 |
I put two 2450mah 3S packs through it yesterday in my normal crawling spot. This time the truck had all the extra scale stuff removed (rack, spare tire, fual cans, etc). It also had my comp tire/wheel setup which is RBXLs, CI 2 stage foams, Incision wheels with Beef Patties up front. I was running with a bone stock TRX-4 too so I had another reference. Removing all the scale stuff really made it less top heavy and I was able to climb up steeper grades without it trying to backflip so easy. It was in the low 80s outside. The motor was getting pretty warm. I changed the pinion setting to D and it still seemed a bit tight and didnt help much with the heat. I see a different powerplant in the near future. I may try the optional 39t spur with 11t pinion and a 3100kv-3500kv brushless setup. This may allow me to keep it in low only. |
I bought this yesterday,post your thoughts please | speedemall | 2.2 Scale Rigs | 28 | 05-30-2010 12:22 PM |
Mounting post placement thoughts | RickM | Paint and Body | 4 | 04-25-2010 04:30 PM |
1/24th Or 1/36th Scale Rock Crawler Please Post Your Thoughts | stomper4x4.com | Losi Mini-Rock Crawler | 66 | 12-18-2009 01:53 AM |
AXLE MODDING for driven/non driven lift axle | SEMIJOE | Non Crawler RC's | 3 | 08-04-2009 04:48 PM |
RCP Crawlers 2.2 Motor Driven Axle Assembly **See a Pic** Post Your Comments | Rockpiledriver | RCP Crawlers | 48 | 12-28-2007 02:09 PM |
