08-03-2017, 11:02 AM | #1 |
Newbie Join Date: Oct 2016 Location: Innsbruck, Austria
| Unpaint the windows?
Is there any way to unpaint the windows without spoiling them? I mean, let the windows 100% clear and not fuzzy. Thanks |
08-03-2017, 11:41 AM | #2 |
Quarry Creeper Join Date: Feb 2017 Location: frothy river
| Re: Unpaint the windows?
I just painted my Grey body and when I was done I briefly attempted to see how hard it would be to remove the grey from the window areas from the underside of the body. I didn't get too far, I tried sandpaper and I may have tried to scrape but its on there pretty good. I don't know of a chemical that is safe for the lexan does anyone? Maybe I should try soap and water it works on some house paints I've used haha. But it said on directions to do that instead of paint thinner,, I only tried because I painted my body externally so whatever I do to the underside is unseen except for the window area If you try and remove the paint from a regular body and you go over the lines or whatever then you'd be over the body paint . Underneath the traxxas black stickers is probably whatever color your body is. On my grey one I have a yellow body and grey windows now the same color the body used to be., it looks Ok actually almost clear in certain light lol. But on a red one I bet its red windows. The underside of my body is white which means they sprayed that white OVER the grey color? If you find out how separate from this thread please come back and tell me : ) Maybe someone will know trick though Last edited by Mountainsofbeer; 08-03-2017 at 11:51 AM. |
08-03-2017, 12:06 PM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Acetone removes most Lexan paints but in my experience it also leaves the Lexan cloudy and brittle. I've heard some people get good results by using a solution of 60/40 water/acetone but I've never tried that myself. I've also heard that using Dot 3 (or was it 4?) brake will take paint off Lexan. I think that requires that the brake fluid being is sit on the paint for a period of time, but not too long. Again, I've never tried this so I can't say for sure. Just do some Google-fu and search "remove Lexan paint". There's a metric shit-tonne of info out there. |
08-03-2017, 12:08 PM | #4 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
I have heard of brake fluid being used to to remove paint from lexan bodies, however it was mentioned it would leave it cloudy. Best option and easiest option I could imagine would be to cut out the windows and glue in some clear replacements... or get a new body.
08-03-2017, 12:15 PM | #5 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Unpaint the windows? Quote:
Ernie | |
08-03-2017, 12:28 PM | #6 | |
Nothing like taking a truck and making it more top heavy! | |
08-03-2017, 12:41 PM | #7 |
Back in the day, RCCA or Xtreme RC did an article about how RTRs are made at the factory including the bodies. It showed how the typical RTR body isn't actually painted, the flat lexan sheet is printed with the design and then molded. Most lexan paint removal tricks don't work on RTR bodies because they aren't painted in the traditional sense. Even if you find a magic combination that removes the paint and doesn't destroy the body, the lexan they are molded in might not even be clear.
08-03-2017, 12:51 PM | #8 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
Let me just save you guys the frustration and time, money, fumes, headache etc. Don't even try to remove Traxxas body paint, it's some kind of Plutonium based etching paint. Brake fluid will partially remove the paint, but will cloud the Lexan and make it very brittle. Any other harsh chemicals or abrasives will only damage the lexan. I'm going to cut the front 3 out and shoe goo or E6000 some clear lexan in, at least on the front windshield. I may only cut down the side door windows to simulate rolled down windows. /\ /\ The post above pretty much spot on. |
08-03-2017, 01:06 PM | #9 |
Buy the clear body. Less mess and frustration.
08-03-2017, 01:59 PM | #10 |
Thank you for all your replies, guys I will forget the idea of unpaint the windows |
08-03-2017, 03:33 PM | #11 | |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
There's some RC4WD defender clone body's on EBay. I got mine for $60 Canadian which is like $45 American. I typed this almost auto correctly free | |
08-03-2017, 03:35 PM | #12 |
| Unpaint the windows? I ended up buying two but I don't know if the WB would match the TRX4 I typed this almost auto correctly free |
08-03-2017, 03:37 PM | #13 |
| Re: Unpaint the windows? Yes, there are d90 2 doors down that low, I have seen them, there is also a d110 which is the 4 door like the TRX but it is well over $150.
08-03-2017, 04:01 PM | #14 |
| Re: Unpaint the windows? |
08-03-2017, 08:33 PM | #15 |
Rock Stacker Join Date: Feb 2017 Location: Canada
guy on one of the FB pages did it. it actually didnt look bad at all.
08-03-2017, 11:00 PM | #16 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
I removed all the paint from my passenger window last night and found that the lexan is not even clear, it's milky and hazy. So I cut all 3 front windows out and just going to drop a piece of lexan in the windshield area.
08-04-2017, 12:16 AM | #17 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
I've used old nitro fuel to remove lexan paint before. Not sure what brand the paint was though. Took some elbow grease, but no haziness/brittleness to speak of.... Sent from my SM-G930V using Tapatalk |
09-01-2017, 07:31 PM | #18 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
RCMart posted this video: |
12-03-2017, 06:05 AM | #19 | |
Newbie Join Date: Nov 2017 Location: Zebulon
Unpaint the windows? - Similar Threads | ||||
Windows 7, Windows Media Player issues | nharkey85 | Chit Chat | 1 | 12-10-2014 08:24 PM |
Windows 7, errrr | losikid | Chit Chat | 9 | 12-21-2012 05:37 PM |
Windows 7 | brushlessemaxx | Chit Chat | 9 | 05-04-2009 06:40 PM |
How many IM windows? | SR5Dave | Chit Chat | 11 | 02-02-2005 07:33 PM |
