Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: New SSD Brass Portal Weights
Old 09-22-2017, 04:30 AM   #1
SSD
Default New SSD Brass Portal Weights
75g each
More details here: PARTS FOR TRX-4 Portal Brass Weights for TRX4
SSD is offline   Reply With Quote
Old 09-22-2017, 06:57 AM   #2
Default Re: New SSD Brass Portal Weights
Price? I guess I'll stick with all SSD stuff for my TRX-4
tuanies is offline   Reply With Quote
Old 09-23-2017, 01:19 AM   #3
I agree these look really nice!!! The design is well thought out, but.......... I'll wait to hear how the bearing pockets fit, as I've had issues with tolerances on SSD products previously. Hopefully the consumer reviews come back positive, these might just get me.
rockhugger is offline   Reply With Quote
Old 09-23-2017, 01:57 PM   #4
Now tell me where they are in stock ready to ship?
chipgibbs is offline   Reply With Quote
Old 09-23-2017, 10:13 PM   #5
Those are nice. They work for front and back? I assume they fit inside your wheels?
92fox is offline   Reply With Quote
Old 09-25-2017, 04:39 AM   #6
SSD
Yes they fit front and back as the front cover is the same on both.
These fit inside SSD wheels and should fit other wheels that dont have a rear ring.
THe OD of the part that fits inside the wheel is 35mm (same as our SCX10 II knuckle brass weight SSD00140, I dont think anyone had issues fitting those inside wheels).
Old 12-30-2017, 09:09 PM   #7
I'm very interested in these portal covers, but I have Pro-Line Faultline beadlock wheels, can anyone tell me if these will fit with my wheels?
They do have a rear ring and are a little bit bigger than 35mm but is it too close?
Legweg is offline   Reply With Quote
Old 12-31-2017, 02:49 AM   #8
SSD
Should fit inside the wheel no problem but the supports that come off the hex area may need a little trimming if they touch.
Just some minor trimming to the supports, should be simple.
Old 12-31-2017, 07:34 AM   #9
Ok I see, you are referring to the small bump on top just between the two screws right?
Is it possible to measure the diameter where that bump is? I wouldn't want to grind through the part while trimming...
Old 12-31-2017, 08:16 AM   #10
Oh I think you are talking about trimming the wheel... I see what you mean now...
I thought you were talking about trimming the portal covers, so I was only looking at the covers
I still wonder about that bump though... I just looked on my TRX-4 and the beadlocks rings don't have much clearance with the top of the stock portal covers, like 1mm, it's a tight fit. If it does rub on top of the cover, is there any room on the covers to trim without breaking through in that area?
Old 12-31-2017, 09:31 AM   #11
SSD
As long as your measurement is ok they will fit.
Old 12-31-2017, 12:43 PM   #12
Ok thank you I'll order a set, along with the SSD aluminum servo horn
Old 01-03-2018, 10:49 AM   #13
The bearing fitment on these are Perfect. The Bearings have to be perfectly aligned to press them in, and are a very snug fit, I think the top ones are going to be tough to get back out when needed.
I had one that was very tight to get in, but I was still able to.
Overall I am very happy with them , and they are on all 4 corners of the T-reXJ.
jhghah is offline   Reply With Quote
Old 01-03-2018, 07:49 PM   #14
If the need arises to replace worn bearings that are in a blind hole, easy peasy.
All you need is a little bit of sliced white bread, just press it in the hole and compress it, add more compress it, add more compress it....the bearing will pop right out !
I’ve done this a few times with cars and trucks and machinery. Either use a bolt real close to the size of the hole or use a drill bit upside down, just use a brass hammer so you don’t damage the tip of the drill bit.
https://youtu.be/Xe-wm47OAP4
https://youtu.be/00OlG5E8vLk
ScoJac is offline   Reply With Quote
Old 01-03-2018, 11:11 PM   #15
I have used the bread trick to remove clutch pilot bearings in the past with great success. Generally the bread trick requires an air pocket behind the bushing/bearing in order to generate the pressure to move it. These portal covers don't have any space behind the bearings so I am not sure it would work. I found a dental type pick works best to just pick the bearing out.
Inspector86 is offline   Reply With Quote
Old 01-04-2018, 05:24 AM   #16
binaryterror's Avatar
I have always used grease to get out bearings like that, at least until a pick can get under it.
https://www.youtube.com/watch?v=2TBZH5R4Cno
binaryterror is offline   Reply With Quote
Old 01-13-2018, 10:17 AM   #17
Is there any downfall to running these portal covers in the mud? Is the fit tight enough in the wheel to create an issue with rocks or mud between the tire and the wheel?
Stewdog is offline   Reply With Quote
Old 01-13-2018, 10:41 AM   #18
Rocks and dirt are always a possible problem no matter how much clearance you have. If the wheel clears the portal cover then go for it. You can't worry about some random stone getting in the way. It's called Murphy's Law.
Old 01-13-2018, 11:26 AM   #19
Thanks! Just making sure I'm not being an idiot and missing some common issue that others have found before me. I'm going to order a set for the front and see how they work for my terrain.
I have a fleet of bashers and a couple road cars, so I get the anything can/will happen scenario.
Old 01-25-2018, 07:39 AM   #20
Ok so i finally received my SSD portal weights yesterday and installed them, it's a tight fit but they do fit with the Proline Faultline beadlocks, the beadlock inner rings were rubbing very very slightly on top, i just sanded the top of the portal weights a little and they don't rub anymore, I will also sand the inner beadlock rings just to get some more clearance
Those portal weights are very nice parts, as mentioned earlier in this thread, the top bearing is a tight fit but it does get in there. I'm very satisfied with my purchase
New SSD Brass Portal Weights - Similar Threads
New SSD Brass Knuckles SSD Vaterra Ascender 29 11-29-2018 08:47 AM
Inner Brass Portal Covers. djmaincheese Traxxas TRX-4 13 09-27-2017 02:17 AM
Hot Racing Brass Knuckles and SSD Brass Weights compatibility saddlesore Axial SCX10 II 5 07-15-2017 04:27 PM
