05-15-2019, 04:09 PM | #1 |
Newbie Join Date: Dec 2018 Location: Jacksonville
| GTS Long shocks - Bump Stops??!
Picked up a set of the long GTS shocks only to find this half inch long bump stop taking up a ton of travel. Is there any real reason to keep these on?? Is it something to do with limiting fluid compression?! Seems like a waste of perfectly good travel to keep them on...what's the point of longer shocks then?!
05-15-2019, 10:56 PM | #2 | |
Quarry Creeper Join Date: Nov 2018 Location: Oakley
| GTS Long shocks - Bump Stops??! Quote:
I believe it has to do with limiting travel for the long arm kit so it doesnt hit the lowered servo mount. My research on the shocks suggets the shaft is 10mm longer and the body is 10mm longer so you should be able to just remove the bump stops and use the full travel. Ive been getting ready to try longer shocks, but not the long GTS ones. I already bought some taller shock towers. | |
05-17-2019, 07:07 PM | #3 | |
Newbie Join Date: Sep 2017 Location: Canada
| Re: GTS Long shocks - Bump Stops??! Quote:
Sent from my SM-G955W using Tapatalk | |
GTS Long shocks - Bump Stops??! - Similar Threads | ||||
axle stops/bump stops limit axle upward movement | meanbgreen | General Scale Talk | 7 | 01-27-2012 03:02 PM |
remove bump stops from shocks | callahanc83 | Axial SCX-10 | 6 | 06-24-2010 10:15 AM |
Bump stops? | starvenamrvin | General Scale Talk | 3 | 01-27-2009 02:03 PM |
RC bump stops | RockCrawlingKid | General Crawlers | 8 | 01-11-2008 05:34 PM |
bump stops | GOMUDN | General Crawlers | 10 | 05-12-2006 06:28 AM |
