Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: red 2 pin connector
Old 02-21-2018, 06:48 PM   #1
Default red 2 pin connector
Just got my first electric scale crawler. Took the lid off to investigate and decide what I'm going to keep and or modify as I'm hoping to get heavily into competitions. But being new to this side of the RC world I for the life of me can't figure out what the red 2 pin connector is for the sits beside the esc. I can't find a function for it and I looked over all the material that the truck came with can't find anything on what it's for. I almost think its for stealing power off the system for something else like lights or winch but I'm not sure. Anyone know?
FANATICRC is offline   Reply With Quote
Old 02-21-2018, 07:02 PM   #2
Default Re: red 2 pin connector
It's for the power supply unit for the Traxxas lights. There may be other uses, but that is the one I have used it for.
https://www.amainhobbies.com/traxxas...ra8028/p705898
Stewdog is offline   Reply With Quote
Old 02-22-2018, 03:25 PM   #3
it's a direct connect to the lipo i have hooked up my steering servo, my led bars and my roocklights over this connect. only thing is all have to be able to handle the voltage of the bat.
magic_yeti is offline   Reply With Quote
Old 02-23-2018, 10:49 AM   #4
Natedog's Avatar
Are you sure? Did you use a meter to test the leads?
Old 02-23-2018, 11:16 AM   #5
Pretty sure you can see it on a closer look how it is wired to the esc - together with the battery leads
Never measured it before, but you can mentioned it, that if you connect the battery it's direct powered.
Only for you natedog i have measured it - right now and yes direct lipo power. So 1000% sure now.
red 2 pin connector - Similar Threads
pin to pin wheel widner johnnyh66 Tires and Wheels 8 06-01-2011 10:25 AM
Pin-to-pin axle width? the_ghetto_rig Duratrax Cliff Climber 0 10-03-2010 02:46 PM
