Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX-4 shocks number designation?
Old 02-26-2018, 10:04 AM   #1
Default TRX-4 shocks number designation?
Could someone with a TRX-4 check the shock ends of their rig, and see if there's a number on them... I bought take-offs on the fleaBay and since they are assembled already, with oil and everything.... I'm curious which are fronts and which are rears.
1 pair has a "1" and the other has a "2"...
It'd be much appreciated!
durok is offline   Reply With Quote
Old 02-26-2018, 10:31 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: TRX-4 shocks number designation?
I will when I get home if somebody doesn't get to it by then.
Old 02-26-2018, 10:33 AM   #3
Are they Tactical or Defender take offs? The tactical uses the same spring rate front and rear whereas the Defender uses stiffer springs in the rear.
Sneetches is offline   Reply With Quote
Old 02-26-2018, 10:50 AM   #4
Can't find a number on them on a quick look, but the rear springs of the defender rtr are marked green.
On a closer look i found the numbers on the rods but that won't help you all my 4 shox have number 1 so the color marker on the springs is the way to go
magic_yeti is offline   Reply With Quote
Old 02-26-2018, 12:00 PM   #5
Thanks guys! Loads of responses.... Couldn't ask for more! I'm also at work right now, but I will at least know which ones to install where now... Testing them on my Ascender K10, with multiple shock locations on the Boom Racing mounts.
Old 02-26-2018, 02:51 PM   #6
Moderator
I don't see any numbers. Are you seeing them on the top or bottom end?
Old 02-26-2018, 05:40 PM   #7
No stripe goes in the front and the green goes to the rear.
edit: oops, I just seen magic_yeti's post above.
ScoJac is offline   Reply With Quote
Old 02-26-2018, 10:44 PM   #8
Gotta pic - no stripes on springs - number on bottom rod-ends - guessing they are Tactical take-offs:
Old 02-27-2018, 08:12 AM   #9
Is there any difference between the stock shocks and the GTS ones other than colors? Look the same.
penguin1 is offline   Reply With Quote
Old 02-27-2018, 08:13 AM   #10
Moderator
The photo of the Tactical shows green springs in the rear here: https://traxxas.com/products/landing...-Gallery-4.jpg
Here are the PDFs to the front and rear. Interestingly, the rear shows the shock parts breakdown, but the front does not.
Front: https://traxxas.com/sites/default/fi...20Assembly.jpg
Rear: https://traxxas.com/sites/default/fi...20Assembly.jpg
TRX-4 shocks number designation? - Similar Threads
Number 13 is on the way ROCKEDUP RICKY Chit Chat 24 12-20-2011 03:24 PM
Stop illegal wilderness designation, save our public lands DeaDShorT Chit Chat 27 01-31-2008 08:20 PM
