Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: About to purchase trx4... What batteries?
Old 04-27-2018, 06:24 PM   #21
Default Re: About to purchase trx4... What batteries?
Originally Posted by Natedog View Post
X2 and this is an excellent LIHV battery that gets hours of runtime even in TRX-4, they are worth the price imo, plus small compact size can mount forward and low in my modded Ascender batttery tray.
https://www.amainhobbies.com/protek-...116-17/p662759
I'm liking these batteries as well.
Tossedman is offline   Reply With Quote
Old 05-05-2018, 08:16 PM   #22
I'm pretty stoked that I may finally have a friend joining me in crawling - he is getting the new Bronco TRX-4.
What battery recommendations do people have for use in the smaller FRONT transverse location that is specific to the Bronco and the kit version of the TRX-4?
Hopefully ones with a fairly high mAh capacity?
Any tips would be appreciated, he will be likely picking up the vehicle in the next week or so.
durok is offline   Reply With Quote
Old 05-05-2018, 08:27 PM   #23
I just run traxxas my self. I have not had problems. I think its just the the easy to side of it a lot of first timers will like. I just got a deadbolt 2 so I had to buy a charger and went with a gen ace battery. Curious how it will compare to the traxxas ones I have.
RC_Propaganda is offline   Reply With Quote
Old 05-05-2018, 08:40 PM   #24
Appreciated, but I'm experienced with LiPo's, and we aren't going to spend the money on Traxxas.
This is a specific request for a specific size LiPo, not for use in the long center location.
We want to use the front location in-between the wheels, just behind the bumper.
Thanks for the input.
Example - Traxxas states that LiPos for their 1/16th vehicles will fit - so I used measurements from one of the Traxxas packs (88mm x 20mm x 35mm), and found this on the HobbyKing LiPo-Finder:
https://hobbyking.com/en_us/turnigy-...ery-xt-60.html
I'd like to find something with a little more capacity that is still a quality battery - with a decent C rating...
Old 05-06-2018, 03:44 AM   #25
if you put a piece of foam to use as a spacer under the battery to lift it off the plate, there is a notched cutout on the fenders and a 2200mAh fits.
ScoJac is offline   Reply With Quote
Old 05-06-2018, 05:06 AM   #26
From playing around with The Turnigy 2.2, it will almost fit but not quite. You can stand it up but it might be difficult to keep it secure/ stable mounting it that way. Laying it down like normal will only work if you trim out a little bit from one of the notched fender cutouts. Even lifted off the plate by at least 12.16 mm ( in order to fit the battery into the notched cutouts) you'd still need to remove a bit of the fender due to the wires. It's doable but not without some trimming. At least from my findings, you'd have to mount it a minimum of 23.06 mm above the plate in order to put this particular battery up front with no trimming. Battery width is perfect but length due to the battery/ balance leads will mean either trimming or mounting it above the fender cutouts.
high plains drifter is offline   Reply With Quote
About to purchase trx4... What batteries? - Similar Threads
Need Help! Purchase Help thegreatgeekyme Newbie General 0 03-14-2012 05:18 PM
how to purchase s_brown04x4 Newbie General 4 02-05-2010 06:27 AM
New Purchase MDcrawler72 Maryland 6 12-02-2008 05:59 PM
