07-20-2018, 11:49 AM | #21 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: What did you do to your TRX-4 today? Quote:
The bowhouse battery tray is great, makes a big difference over stock. Please update on how you feel about your wheel speed with that motor and the single speed transmission. | |
07-20-2018, 02:01 PM | #22 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
Well that doesnt look too bad considering you run the smaller Swampers? I plan on running Hyrax, and with alittle droop on the shocks, it might look pretty good accually. Thanks for the pic's |
07-20-2018, 07:32 PM | #23 |
My #3 TRX4 came to life this week. This one started as a bare chassis I picked up from ebay several months back. It is equipped with a stock TX/RX, Savox 1230SG, TRX4 Titan 550 21t motor with a HW1080 ESC, underdrive gears, Yeah racing axle housings, all aluminum axle parts, SSD portal weights, MIP driveshafts, Dravtech shocks, VP 2.2 Method 105 wheels, 1.9 PitBull Growlers. Truck drives really smooth on my rock pile, looking forward to spending some trail time with this one. I have both the red decal set and the sunset decal set but I like it all black. Last edited by Inspector86; 01-28-2019 at 11:32 AM. |
07-20-2018, 09:32 PM | #24 |
Rock Stacker Join Date: May 2018 Location: northern illinois
the all black does look sexy.^^^ so tonight went over to a buddy who crawls and we did some drenching(drinking and wrenching). managed to wire up a heyok "the lighting controller" and get my vanquish lightbar mounted to my rollbar. had to fab new brackets from alum L so I could use the stock mounting holes in the rollbar. when moding my front inner fenders to fit the highlux I lost the front rocklight holes so I fabbed up some light buckets from mirrored styrene and screwed them to my front fenders. then screwed the front rocklights to the buckets. rock/headlight brackets 2 trx4's mine and my buds Last edited by zohn; 07-21-2018 at 07:00 PM. Reason: added missing pik |
07-22-2018, 07:52 PM | #25 |
wired up some rear tail light buckets for the hilux but am waiting for paint b4 I install. plugged em in to the light controller and all worked well. liking the hey ok controller straight forward and ez to use. worked on me and my buddies backyard crawler course for a bit and then broke the cherry on the hilux body and did some crawling. |
07-22-2018, 08:03 PM | #26 |
Newbie Join Date: Jun 2018 Location: US
| Re: What did you do to your TRX-4 today? Quote: Sent from my SM-G960U using Tapatalk |
07-22-2018, 09:18 PM | #27 |
Quarry Creeper Join Date: Feb 2016 Location: Pembroke ON Canada
Order a back up Bullhead body for my trx4 trail build. Sent from my FRD-L14 using Tapatalk |
07-23-2018, 10:48 AM | #28 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
Finished the roll bar finally. Sent from my iPhone using Tapatalk |
07-23-2018, 11:42 AM | #29 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
New shiny wheels. Sent from my SM-N910P using Tapatalk |
07-23-2018, 05:31 PM | #30 |
| Re: What did you do to your TRX-4 today? |
07-24-2018, 05:28 PM | #31 |
Newbie Join Date: Jul 2018 Location: St. Louis
Added a gopro mount to the rear bumper: Last edited by chvvkumar; 07-24-2018 at 05:31 PM. |
07-24-2018, 06:21 PM | #32 |
| Re: What did you do to your TRX-4 today? Installed new Vanquish Method 101 beadlocks! Sent from my iPhone using Tapatalk |
07-24-2018, 06:58 PM | #33 |
got a package from shapeways today. a front grill from rcnerds and a 0v 0h bumper mount. I had a 0v 11.5h on my front and a stock traxxas front on my back. put the 0v 0h on my front and gained a bit of approach angle. took the 0v 11.5 and put it on the back so gained a bit there to. before after need to do some polishing on these lenses and some super fine sanding on the grill to get rid of the step lines |
07-24-2018, 07:33 PM | #34 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Put some Proline Hyrax 1.9 x 4.73 on my SSD wheels. Made a snatch strap from a shoe lace. Reattached the hitch on my rear bumper & made a receiver for my snatch rope. Getting prepared for my first comp on Sunday Sent from my SM-S975L using Tapatalk |
07-25-2018, 08:48 AM | #35 |
Newbie Join Date: Jun 2018 Location: Austin
RC ADHD, Still have not gotten the servos lined out on the Flysky trans/receiver combo, but it should happen this week as I am home alone. Instead of working on that I went for an evening crawl with a biddy and his Ascender. We ended up on a small outcrop of rock near a creek after an unintentional change of plans. It was not a huge area but provided a few hours of trying different lines some more challenging than others. On a side note my last "mods" to my simpleton Bronco were an oil change on the shocks (team associated 30wt), and setting the diff lock switch to Rear only, Both, Front only. I am loving these changes. I can do donuts on loose surfaces with out rolling now, I also seem to have way fewer tips and flips than previously, though this could be increasing my driver mod skill points from more and more driving. We waited to the last minute to stop for some photos. |
07-25-2018, 09:41 AM | #36 |
Got some more shock oils to try out (losi 20 and 25 and team associated 10). Ordered the hot racing high clearance steering rod. and got the trx4 a friend Update: got the high clearance rod installed. Much more clearance and improved my steering radius after resetting end points. I had to use the stock rod ends though because the hot racing ones wouldn’t fit with the Samix brass, they were too thick. Last edited by Topher Builds; 07-25-2018 at 05:05 PM. |
07-25-2018, 03:42 PM | #37 |
Pebble Pounder Join Date: Oct 2016 Location: Philly Area
07-25-2018, 03:49 PM | #38 |
07-25-2018, 05:23 PM | #39 |
Installed new bumpers front and rear on my #3 TRX4 Bronco today. |
07-26-2018, 03:50 AM | #40 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
What did you do to your TRX-4 today? - Similar Threads | ||||
My 2.2 TRX-4 | Kawirocket674 | Traxxas TRX-4 | 9 | 07-23-2017 06:19 PM |
