Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: What are these screw posts for??
Old 09-01-2018, 07:06 PM   #1
Question What are these screw posts for??
Hey does anyone know what these screw posts are made for?
Snowflake is offline   Reply With Quote
Old 09-01-2018, 07:08 PM   #2
Default Re: What are these screw posts for??
Those are the mounts for the Traxxas 8028 power supply which is used to power the Traxxas 8030 light kit. The 8028 power supply also is powered by the red JST plug you asked about earlier.
Inspector86 is offline   Reply With Quote
Old 09-01-2018, 07:16 PM   #3
Ok cool... if I'm going to install the mytrickRc light kit do I still need that plug? If not can I wire the plug up to my BEC for my servo?
Old 09-01-2018, 07:28 PM   #4
I wired my BEC to that plug. No problemo.
Tossedman is offline   Reply With Quote
Old 09-01-2018, 07:38 PM   #5
Actually it depends on which MyTrickRC controller you choose to buy. The DG-1 or the UF-7. I think the DG-1 can use that JST plug or direct to the balance plug of a 2s or 3s battery. The UF-7 is connected to ch2 of the RX (optionally also ch1) and is powered at 6v from the RX. I used the JST plug to power my BEC until I changed ESCs.
Old 09-01-2018, 08:11 PM   #6
Not relative to OP's inquiry but I used the jst connector on mine to directly power my HH shv500v2.
high plains drifter is offline   Reply With Quote
Old 09-01-2018, 08:21 PM   #7
Ok cool... Also what are your guys takes on filling your BEC with hot glue to waterproof them?
Old 09-01-2018, 08:24 PM   #8
It may work for a while, but as it heat cycles it will be less effective.
I'd highly suggest some conformal coating or heat shrink with adhesive. 3M 3:1 is what I use.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 09-17-2018, 08:55 AM   #9
kinda related....https://youtu.be/RNqm5O3kN8E
fuceye is offline   Reply With Quote
What are these screw posts for?? - Similar Threads
Stripped Hex Screw - Craftsman Screw Extractor bigstu Tools, and Procedures 8 11-05-2011 08:48 AM
Need help about my posts AX-10 Crawler Comments, Suggestions, and Help 2 08-22-2010 05:30 PM
My posts are going away Greatscott Comments, Suggestions, and Help 27 04-21-2009 03:19 PM
Side posts vs top posts??? Mr_Freeze Paint and Body 11 05-24-2008 02:46 PM
