09-14-2018, 04:43 PM | #1 |
Newbie Join Date: Apr 2018 Location: Usa
| Mamba X HH Puller Pro 540 BL 2700
I installed the above setup in my Bronco the other day. I am using the CC B Link to do the programming. System is running well but having some issues with reverse. I am set up as follows Traxxas radio Reverse Type: Crawler Reverse Brake 30% Drake Brake 100% because it was slightly rolling down hill in crawl mode. this seemed to stop it Start Power High Max P 100% RP 100% Punch 100% Motor Type smart sense brushless Throttle curve is more gradual than stock. It’s great. Brake curve is the problem. I am basically hitting 10% power at 60% input and the truck still wants to flip over backwards with I hit reverse. How can I calm down the reverse or what settings do I have wrong? Sent from my iPad using Tapatalk |
09-14-2018, 04:52 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Mamba X HH Puller Pro 540 BL 2700
Crawler Reverse is direct Forward Reverse no Brake. What you looking for is the Default seting ( with Reverse ). Gesendet von meinem Pixel 2 XL mit Tapatalk |
09-14-2018, 09:26 PM | #3 |
Thanks for the advice but that’s not solving the touchy reverse. If I don’t keep the curve out where I stated in my original post the truck will do a front flip with the slightest press of the reverse trigger. Sent from my iPad using Tapatalk |
09-15-2018, 09:57 AM | #4 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
How fast are you going when it flips over? In general if you have 100% drag brake on and you’re hauling on a surface with any traction you’ll want to gradually ease down on the trigger. Otherwise it will be flip city. I have the same set up in another rig but am using a flysky gt5 and have the aux wire of the mamba x hooked up to a channel with a knob, so I can adjust the drag brake on the fly if I’m ever doing some Miami Vice type cruising. Aside from that, you should be able to custom set your reverse throttle curve. Having it too stretched out can make it a little tougher to reverse out of a potential roll over situation on an incline. Last edited by Topher Builds; 09-15-2018 at 10:04 AM. |
09-15-2018, 10:11 AM | #5 |
Im at a dead stop and when I push reverse it happens so fast and powerful it will flip the truck. For me to get revers where its manageable I have to set the reverse curve up as indicated in the attached photo. It seems weird that reverse has so much more start power over forward. My forward throttle curve is included as well. First photo is reverse and 2nd is forward. |
09-15-2018, 12:59 PM | #6 |
Hmm. Tbh you may like your forward being curved like your reverse. But if it’s still that bad maybe try resetting the throttle expo on your transmitter.
09-15-2018, 06:01 PM | #7 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
My bomber did that to me in reverse with the MX and PP2700 using a B-link programmer. It did that a couple times finally I reset the defaults then made all the changes again and it worked fine after that... I did mimic the forward curve so that I ended up with the same low speed control in reverse. If it does it again just try resending the settings to the esc again, it’s almost like it jumbled the code a bit ?
09-15-2018, 09:56 PM | #8 |
So I have a couple of things going on that I think were causing the problem. 1. The remote was in the 70/30 position so that was making the reverse touchy I think. 2. The remote seems to have a lot of play in it before the car starts reacting to the trigger inputs. So I restored to defaults, brought the controller back to 50/50, and recalibrated the controller and still did not notice any change. Next I took it back to the settings listed in the first post, reset the throttle and brake curves back to what I had earlier, recalibrated the controller again to 70/30 and still did not notice any difference. What did make a difference was lowering the Dead Band to the lowest setting. That seemed to take the play out of the remote and give me better trigger control. I still think reverse is more touchy but its much better. Thanks for all the ideas folks! Sent from my iPad using Tapatalk |
09-15-2018, 11:04 PM | #9 |
Rock Stacker Join Date: Sep 2018 Location: boise
Hope I’m not out of line but, when your going forward is your esc blinking green and red in reverse. If not you need to reverse rotate the motor if you haven’t. That is required for the trx4. Just something I couldn’t figure out at first with my mamba X
09-16-2018, 03:12 AM | #10 |
Something else to try. I'm sure you have already seen it but if you have not watched it yet, check out JohnRobHolmes video he did with the sidewinder4 and revolver. I set up both my MX and thePP2700 and the Revolver exactly the same in the TRX and the Bomber minus the aux wire modes. A couple settings I made different from what you have listed in the first post. John recommends using 30% punch control and I also have my reverse backed off to 75% and my motor timing is at 0% also set both curves to 50% input and 20% output. If it allows it, might try to reload the current firmware, if that works and still no luck after that I'd give Castle a jingle. Oh, what do you have the Aux Wire set up as ? when I first set up the bomber I did the rock racer/crawler mode and it gave me a violent reverse then I changed my drag brake at 10% and dropped the brake amount to 25% and it still did it then i resent the setting and it worked, on the trx I run the aux wire in Drag Brake adjustment mode. Last edited by ScoJac; 09-16-2018 at 03:29 AM. |
Mamba X HH Puller Pro 540 BL 2700 - Similar Threads | ||||
TRX 4 Run time estimate? (mamba X and puller pro 2700) | niro750 | Electronics | 12 | 09-05-2018 08:32 AM |
Puller Pro BL 540 Standard vs Puller Pro BL 540 Stubby | NeoPyro | Electronics | 25 | 08-09-2017 11:15 AM |
Motor Selection Help Needed - HH Puller Pro 540 vs HH Puller Pro 540XL | WesTX | Electronics | 18 | 09-14-2016 09:16 PM |
