Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: hot racing shock tower question
Old 03-09-2019, 06:02 PM   #1
Default hot racing shock tower question
with the hot racing shock towers how do you run the body mounts? i want to make sure they work with the stock defender mounts before i buy them. Thanks
https://www.amainhobbies.com/hot-rac...SABEgLnWfD_BwE
twisted is offline   Reply With Quote
Old 03-09-2019, 07:23 PM   #2
Default Re: hot racing shock tower question
from what ive seen on line there best avoided the panard mount shears off
steven318is is offline   Reply With Quote
Old 03-09-2019, 07:45 PM   #3
Stay away from the HR shock mounts! The pan hard mount is weak and will eventually fail. Here is a pic of one that failed on my #1 TRX4 after about a year of slow rock crawling with no bashing. Note that there is not much cross section of material where the mount broke. This is clearly a design problem but HR will do nothing to warranty their parts after 90 days.
Inspector86 is offline   Reply With Quote
Old 03-09-2019, 10:09 PM   #4
Gold Star Baby!
Topher Builds's Avatar
To answer your question since it will apply to the other options out there, the body mount is part of a brace that is retained and will go between whichever shock towers you end up with.
Topher Builds is offline   Reply With Quote
Old 03-10-2019, 12:27 AM   #5
Here are the Samix ones I ordered and installed. As you can see in the second picture is how the stock mount is still utilized.
The third picture has the beefed up panhard mount.
CRAZYACE63 is offline   Reply With Quote
Old 03-10-2019, 02:03 PM   #6
thanks guys for the info.
Old 03-11-2019, 03:59 PM   #7
So samix is the way to go? Do they let you run a longer shock, or is the top hole stock height?
mass-hole is offline   Reply With Quote
Old 03-11-2019, 04:27 PM   #8
I have mine set in the middle hole. It may let you run longer shocks. I only have stock kit shocks so I don’t know the differences. Sorry.
Old 03-11-2019, 04:34 PM   #9
Ive got a pair of 110mm Hot Racing shocks I bought to test on my Rock Rey and they have a strange amount of travel. Like they were the same length compressed as the 100mm factory shocks but 10mm longer extended. Id be sweet to run those at like 40-50% droop and get a lot of articulation.
hot racing shock tower question - Similar Threads
Shock tower to shock tower carbon fiber chassis brace Crazykev Axial Yeti 0 04-23-2016 12:48 AM
Hot racing shock cap binding Dionisi Axial Yeti XL 0 05-29-2015 09:21 AM
Xtreme Racing Carbon Fiber front shock tower Verboten77 Axial Yeti 2 03-10-2015 10:33 PM
shock options and hot racing spoo76 Losi Micro-Rock Crawler 0 12-29-2009 09:35 PM
