04-08-2019, 06:08 PM | #1 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Calling all Traxxas TQi Link experts
I got the Traxxas bluetooth Link module for the TQi radio and I'm having a strange problem. I got everything dialed in just right when the transmitter is connected to the app, but I haven't been able to retain all of those settings in the transmitter when not connected. Specifically, when I turn the transmitter/receiver off and back on, my steering endpoints are gone until I get my phone out and reconnect to the app. Then the endpoints are instantly back, without even loading a profile or doing anything else. I've tried saving the profile and then loading it before disconnecting, but the same thing still happens. Maybe the endpoints aren't meant to be retained without connection to the app, but that would be strange because most of the other settings like steering sub-trim are retained. Any thoughts? Am I missing something? I was able to stump Traxxas tech support with this over the phone. If they get back to me with an answer I'll update here. |
04-09-2019, 08:52 AM | #2 |
| Re: Calling all Traxxas TQi Link experts
Poking around in the app I found this "override transmitter settings" option, which was/is turned on. So apparently what happens is the app connects to the transmitter and then the transmitter's settings are overridden and I get my steering endpoints back. But why don't those endpoint settings stay saved in the transmitter after it's turned off? Everything I've read suggests the transmitter should automatically keep all the settings from the app. |
04-09-2019, 09:55 AM | #3 | |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: Calling all Traxxas TQi Link experts Quote:
This is how mine has always worked. I use the App to setup everything and then may not open the app for some time but the transmitter retains all settings. Make sure to be properly selecting the vehicle you want. I believe you have to turn on the vehicle first so the receiver is powered up and then the transmitter. | |
04-09-2019, 10:48 AM | #4 |
do the TX and vehicle icons turn green when connected?
04-09-2019, 12:29 PM | #5 |
I hate to ask the dumb questions, but... 1. Have you tried re-binding the receiver? 2. Is the receiver updated to the latest firmware? 3. Do you have another TQi receiver to try? |
04-09-2019, 12:48 PM | #6 | |
Wow. I can hold the transmitter wheel hard right and the servo will overtravel and flex all the plastics, and then if I open the app while I'm holding it there the servo will snap back to the correct endpoint as soon as the bluetooth connection is made. Incredibly frustrating. I spent (wasted?) the money on this Link module specifically to make these adjustments easier, and because I need to keep the stock radio in this truck. I might be speaking too soon but it looks like Traxxas tech support is gonna leave me hanging. Help!!! Quote:
Yep, I took that screenshot when they were disconnected. | |
04-09-2019, 12:51 PM | #7 | |
2. Yes, the app gave me no choice 3. Nope Keep the dumb questions coming though Never thought I'd see the day when working on an R/C is like struggling with tech support for a computer. Ugh. | |
04-09-2019, 01:20 PM | #8 | |
Newbie Join Date: Oct 2018 Location: US
Sent from my Pixel 2 XL using Tapatalk | |
04-10-2019, 11:19 AM | #9 | |
Traxxas tech support called me back with some ideas to try, none of which worked but at least they got back to me. Based on what they were telling me to try and what I've read online, I came up with the following list of steps to hopefully reset everything to the fullest extent possible. Some of this is redundant but I'm trying to really cover all the bases before I give up. 1. Delete all settings in app and uninstall app from phone. 2. Remove Link module from transmitter. 3. Do the procedure to reset transmitter to factory default settings. 4. Re-bind transmitter to receiver. 5. Reinstall app on phone. 6. Reinstall Link module in transmitter and reconnect to app (with both Tx and Rx turned on). 7. Vehicle Selection in app: choose TRX-4 chassis kit. (It defaulted to TRX-4 Tactical for some reason, which shouldn't make a difference even though it's not the exact model I have.) 8. Delete TRX-4 Tactical from vehicle history in app. 9. Use the app to adjust all the trim settings again. 10. Disconnect from app and then see if the problem persists. Will report back after I try this. | |
04-10-2019, 11:39 AM | #10 |
Pebble Pounder Join Date: Jul 2013 Location: Germany
| Re: Calling all Traxxas TQi Link experts |
04-11-2019, 07:11 AM | #11 | |
I actually don't think this is related to the Link app at all. If I stay disconnected from the app and set the endpoints manually on the transmitter using the menu/set buttons, it STILL loses the endpoints if I turn the TX/Rx off and on. I may call Traxxas tech support one last time but honestly I need to step away because I'm to the point of giving up and selling the truck. Struggling with the same stupid problem every day for a week has a way of sucking all the fun out of a project. I could just connect to the app every time I turn the truck on but that seems like a really lame workaround on a project that was going to cost around $1000 to finish. | |
04-11-2019, 07:12 AM | #12 | |
04-11-2019, 09:50 AM | #13 |
I called Traxxas again and we tried a few more things and they agreed it sounds like a bad transmitter. They're sending out a replacement. For what it's worth, Traxxas tech support has been good to work with on this. No escalation to management was needed to get the replacement, just a proof of purchase. I hope it works out because I really don't want to give up on this build! |
04-11-2019, 09:53 AM | #14 | |
I wouldn't want to see this build die either. I'm looking forward to seeing it finished. | |
04-19-2019, 09:14 AM | #15 |
Update: the new transmitter came in and the problem persists. At this point I have to assume it's a software bug. Hopefully it will be addressed in a future firmware update. Until then I'll have to connect to the app before every drive. Annoying and inconvenient, but it is what it is.
03-04-2022, 02:14 PM | #16 |
Newbie Join Date: Jan 2022 Location: TORONTO
its now 2021 and I'm having the exact same problem. The app settings are not applied unless the app is running and connected to the receiver. Otherwise the TRX4 has really narrow endpoints when I start up without the app. I have no idea where those settings are coming from. I've tried resetting the transmitter to factory defaults but did nothing. I've tried uninstalling/reinstalling the app - no luck. I only have one profile defined in the app. I was going to call Traxxas but based on the OPs description, they don't know what the problem is. Maybe they learned something in 4 years? Maybe I'll try calling. |
08-04-2022, 02:09 AM | #17 |
Newbie Join Date: Jun 2020 Location: UK
I rebuilt my TRX4 with Traxx, and I installed a Savöx SW-2210SG servo to provide extra steering power. When I tried to set the steering end points on the TQi transmitter, I ran into the same problem. I don't have a Link module, so I set the limits using the buttons. After numerous experiments, I discovered two things: 1. You must not have the steering direction reversed. If you do, the end point setting procedure goes mad and can cause the steering servo to thrash. You have to set it to the default direction before setting end points. 2. Once the end points are set, you can turn off the TX or the RX and the end point settings are retained, but if you turn off both TX and RX, the end point settings are lost. Surprisingly, the steering direction setting is retained. This has got to be a firmware problem. It is very disappointing that despite reports of the problem since 2019, it has not been fixed. I sent an email to Taxxas support but they just suggested updating the firmware. I asked for the firmware Release Notes to see if they had corrected the problem, but they said that they don't provide those. Fortunately, I was able to fix my end point problem with some mechanical changes. Incidentally, my tracked TRX4 has a Hobbywing Fusion combined motor and ESC. The power and battery life are much better than they were with the standard 21t 550R motor. Last edited by Thunderdonkey; 08-06-2022 at 04:11 AM. |
Calling all Traxxas TQi Link experts - Similar Threads | ||||
Calling all evx-2 & summit experts!!! | Dtomblin | Electronics | 1 | 02-21-2015 07:35 AM |
Calling all video experts | mr.maxx | Chit Chat | 4 | 08-05-2006 06:28 PM |
Blowing gearboxes like crazy, calling experts! | mattnin | Traxxas Crawlers | 20 | 05-15-2006 10:09 AM |
