05-20-2020, 01:54 PM | #1 |
Newbie Join Date: May 2020 Location: N.W.I.
| speed controller issues
I can't get the speed controller set to level 5 setting. Should I change the speed controller to another brand? What brand will work with the traxxas receiver?
05-20-2020, 02:13 PM | #2 |
| Re: speed controller issues
I am going to assume you are referring to the stock TRX4 XL5 ESC since you did not provide a great deal of information. Short answer is, It Depends. What do you want to accomplish? What kind of driving do you normally do, fast or slow? What motor are you running or want to run? Again, assuming you are running the stock TRX4 Titan 550 21T motor the go to replacement ESC is the Hobbywing WP1080 for $42. Under no circumstance would I ever recommend spending money on a replacement XL5.
05-20-2020, 06:04 PM | #3 | |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: speed controller issues Quote:
I couldn't have said it better myself. Most ESC will work with that TX with no problem. Hobbywing 1080 is by far the way to go without breaking the bank. | |
05-20-2020, 06:19 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
I built the TRX4 chassis kit and didn't even bother with the stock traxxas esc I went straight to the Hobbywing HW1080
05-20-2020, 07:48 PM | #5 |
ok. thank you for the information.
speed controller issues - Similar Threads | ||||
Help! Apparently GoPro wi-fi is 2.4 ghz and and is causing issues with controller... | InspectorWally | Electronics | 9 | 03-14-2014 10:57 AM |
speed controller | fej68 | Axial AX-10 Scorpion | 3 | 10-16-2011 08:23 PM |
3racing winch controller issues | Cordwood | Electronics | 3 | 08-25-2011 08:18 AM |
Speed controller | tecboy | Electronics | 6 | 02-04-2010 02:40 PM |
speed controller | clod driver | Electronics | 4 | 05-28-2009 01:02 PM |
