05-30-2020, 01:07 AM | #1 |
Rock Stacker Join Date: Dec 2017 Location: Greece
| GPM Racing pendulum weights installation issue
Good morning everyone. I bought a pair of these https://www.gpmracing.com.hk/en/prod...3302&fid=&cat= but i have some issues installing them on the stock portals of the sport kit. The wheels won't screw correctly in place. Is there a way to make the shaft longer or something? Or maybe someone here uses the weights on his truck?
05-30-2020, 01:27 AM | #2 |
| Re: GPM Racing pendulum weights installation issue
What wheels are you using? Adding weights to the already large portal box's might leave too little room for wheels, you may need different wheels. I like SSD's steel wheels, they have just about the max amount of clearance you can get from a 1.9" wheel. Alternatively you could extend the track width with wider wheel Hex's, though at a certain point it becomes detrimental to the steering. MIP makes a kit to extend the track width but IMO this is far too wide and steering will definitely suffer, these also introduce body rub/clearance issues due to the tire taking a larger arc https://www.rpphobby.com/product_p/mip18260.htm Or you can do like I've done on one build and file the weights until it clears the wheels you want to use. Last edited by HumboldtEF; 05-30-2020 at 01:35 AM. |
05-30-2020, 01:42 AM | #3 | |
| Re: GPM Racing pendulum weights installation issue Quote:
GPM Racing pendulum weights installation issue - Similar Threads | ||||
Hot Racing Steering Bellcrank vs. GPM | dempy | Tamiya XC/CC01 | 15 | 03-07-2016 05:26 AM |
GPM Racing Trailer Hitch | GodSpeed999 | Axial SCX-10 | 5 | 10-16-2014 11:02 AM |
GPM Spur gear for CC01- issue? | kevin107 | Tamiya XC/CC01 | 6 | 09-21-2012 10:24 AM |
GPM Vs Yeah Racing Billet parts | STANG KILLA SS | Non Crawler RC's | 3 | 03-12-2010 02:53 PM |
GPM racing 2.2 crawlerwheels | niklass | Tires and Wheels | 6 | 09-04-2009 06:31 PM |
