01-30-2021, 05:47 AM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Merrimack
| Scattergun V2
Started a new project All disassembled Slowly coming together. Need to make a few modifications Time for the electronics Now time to figure out the body. |
01-30-2021, 06:19 AM | #2 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Scattergun V2
Nice! I’d like to hear how much better it crawls and how you like it! Let us know! _________________ SCX10 ii TRX4 |
01-30-2021, 06:38 AM | #3 | |
| Re: Scattergun V2 Quote:
Waiting on different body mounts to arrive before I test. Plus it’s only 4 degrees outside so I’ll have to wait till next Saturday to test at my local indoor course. | |
01-30-2021, 11:55 AM | #4 |
Newbie Join Date: May 2019 Location: Skåneland
| Re: Scattergun V2
I was just checking this out and wishing there was a build tread about it, really excited to see how this turns out! Skickat från min SM-G970F via Tapatalk |
01-30-2021, 12:13 PM | #5 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Scattergun V2
I recently built a Scattergun TRX4. the chassis allows for more susp movement. I did servo on axle in front and the Scattergun chassis allows for more upward travel in the front. I went with longer shocks on the back and again far more room for upward travel. I went with the bowhouse skid and it fit nicely. I did have to cut a bit of the chassis to fit my transmission servo. https://i.ibb.co/wh6Dscy/trx.jpg Last edited by MOguy; 01-30-2021 at 12:23 PM. |
01-30-2021, 01:12 PM | #6 | |
I had to cut part of the chassis to fit my 2 speed servo, and trimmed up the stock skid plate. Also had to trim the aluminum Integry motor mount. Overall I’m happy with the outcome. Not as much flex as I expected but it’s definitely no less then stock. Also remounted my electronics and moved my battery upfront. | |
01-30-2021, 01:56 PM | #7 |
| Re: Scattergun V2
If you want more room for susp movement up front ditch the panhard bar, go 4 link and do a servo on axle. Even if you keep the panhard bar once you figure out which hole you want to mount to you can probably cut off half the scatter gun panhard mount off or better yet get a TGH panhard mount. The scatter gun mount is just TOO BIG and in the way the set it up it is in the way. They rave about how strong and it is strong it is but it is a bad design.
01-30-2021, 03:19 PM | #8 | |
Pictures? | |
01-30-2021, 06:22 PM | #9 |
| Re: Scattergun V2 I thought I did, I will try again. this picture I had a Tweaken 3D printed mount that broke pretty quickly This is a JEC and so far it is much much much better. Last edited by MOguy; 01-30-2021 at 06:55 PM. |
01-31-2021, 08:36 AM | #10 |
| Re: Scattergun V2
It’s done, for now at least till spring when I get a new body. Figured out the body mounts. Reworked the wiring for the lights. Raised the front bumper about a 1/2 inch. Lowered the body as much as possible. Raised the sliders & trimmed the body to fit. Now just need to fine tune the shocks. Here’s how it sits. |
01-31-2021, 10:30 AM | #11 |
| Re: Scattergun V2
Looks great, have fun with it.
Scattergun V2 - Similar Threads | ||||
NWSD Scattergun V2 | PFongemie | Traxxas TRX-4 | 3 | 01-15-2022 07:45 AM |
NWSD Scattergun | haris | HPI Venture | 4 | 12-30-2020 10:54 AM |
G-Speed v3 or scattergun??? | xxlostonexx | 1.9 Scale Rigs | 3 | 11-22-2020 06:54 AM |
