Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Inclinometer reading 30* lean
Old 06-04-2021, 07:06 PM   #1
Default Inclinometer reading 30* lean
So just got the link and updated the rx and rx. Go to dashboard and it's showing the truck at a 30* lean. It's flat on bench. Rx is stock and in stock box. It's flat too. It leans more left or right. The sensor is working just it's out. Can one calibrate or reset them?
DPesonen is offline   Reply With Quote
Old 06-05-2021, 12:15 AM   #2
Default Re: Inclinometer reading 30* lean
There's no way i know of to change that in Software, you can't even reverse it for other Rx mounts.
As ist a mechanical sensor maybe it got a hard bump or something and now is stuck or broken.
You need to replace the Rx (or the chip, if you get one and can solder such small parts...).
amigaman is online now   Reply With Quote
Old 06-06-2021, 10:34 PM   #3
Have a support ticket into Traxxas. Most likely warranty as my rig is stock and I just this week only, opened the RX case to add a Fusion motor.
Inclinometer reading 30* lean - Similar Threads
Reading pa crawlers squirl19 Pennsylvania 3 02-28-2013 05:41 AM
Any one near Reading PA?? mr.maxx Pennsylvania 8 04-01-2012 04:58 PM
Chassis Lean rc2000 Team Losi Comp Crawler 16 10-23-2009 02:28 PM
