Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Binding Losi radio to stock traxas ESC
Old 07-16-2021, 08:01 PM   #1
Default Binding Losi radio to stock traxas ESC
Is it possible to do this?
83trekker83 is offline   Reply With Quote
Old 07-16-2021, 08:32 PM   #2
Default Re: Binding Losi radio to stock traxas ESC
The esc won't be an issue. The receiver needs ro be compatible. The traxxas receivers need traxxas radios. If you meant receiver instead of esc.
Sent from my SM-N950U using Tapatalk
Dirt Runner is offline   Reply With Quote
Old 07-16-2021, 10:18 PM   #3
Yes sorry, i did mean the receiver.
Old 07-17-2021, 12:34 AM   #4
Losi is Horizon Hobby, as is Spektrum, so a Spektrum System would most certainly do.
Traxxas has it's own, a TRX receiver will only bind to a TRX transmitter.
If you want to use your Losi/Spektrum Tx, you'll need a Spektrum Rx.
amigaman is offline   Reply With Quote
Old 07-17-2021, 12:52 AM   #5
Even though Losi and Axial are HH brands, I'm pretty sure they have a proprietary 2.4 protocol and won't work with Spektrum radios. I had a Tx go bad on a HH Proboat brand boat and the stock Rx would not bind to a Specktrum Tx.
OnTheTrail is offline   Reply With Quote
Old 07-17-2021, 06:23 AM   #6
Afaik all HH brands use OEM Spektrum, but you may be right.
I never had a Losi, but my Axial and Vaterra Cars had a Spektrum System, although they were a bit picky with the Protocol to use.
Spektrum had some DSM Evolutions that aren't compatible, whyever.
I've long sold them so no way to check...
Old 07-17-2021, 09:11 AM   #7
So i guess my friend can just buy another Losi radio for his controller than, the radio it has seems to be flaky and cuts ion and out.
Old 07-17-2021, 06:54 PM   #8
I he sure it's the transmitter and not the receiver?
Binding Losi radio to stock traxas ESC - Similar Threads
Binding radio and setting up ESC VR6 BeelzeDub Newbie General 6 09-24-2019 05:48 AM
Binding to a Stock ESC/RX Black Rock Losi Micro-Rock Crawler 2 05-03-2012 12:40 PM
Binding Losi radio to spektrum rx ecoli Electronics 1 03-09-2011 04:25 PM
