Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: VS4-10 Chassis Kit (Unimog)
Old 06-16-2019, 10:02 PM   #1
Default VS4-10 Chassis Kit (Unimog)
Anyone know if the Axial Unimog body/rear cage will fit on the VS4-10 Chassis Kit? I know the transmission needs to be the 3 gear RTR 10.2 version.
Fishcharger is offline   Reply With Quote
Old 07-02-2019, 09:08 AM   #2
Im Brandon
Brandon's Avatar
Default Re: VS4-10 Chassis Kit (Unimog)
The high clearance frame rails will requires some trimming on the cage I would imagine.
The front bumper body post mounting system may require some modification as well.
Anything is possible though!
Brandon is offline   Reply With Quote
Old 07-02-2019, 09:16 AM   #3
Yep finished about a week ago. Worked out good. Left a little extra on the from of the cab when trimming the lexan. And got rid of the the fuel tank cover.
Old 07-02-2019, 01:56 PM   #4
Pictures of it mounted and modifications you made?
Sent from my iPhone using Tapatalk Pro
jrkilburn is offline   Reply With Quote
Old 07-02-2019, 03:02 PM   #5
If you zoom in on the pic of the front you can see I left a little more lexan on. Left the rear fuel tank cover off and used the two little raise screw holes in the back as a gauge to where the back of the body will rest. Then cut them off after all mocked up and trimmed a small piece of the fuel tank cover off and install it. Used spacers to bridge the gap in the holes I drilled into the full tank for mounting the back. Had to get creative with mounting the front mounts. But just mock them up and you’ll figure out a way to mount them. And of course had to use the RTR 3 gear transmission. If you did some modifications and used the kit version skid plate I’ll bet you could make the kit transmission to work.
Old 07-02-2019, 03:04 PM   #6
https://youtu.be/y-0ojVfHZio
Old 07-03-2019, 01:13 AM   #7
Turned out great. Did you use the 12" Wheelbase link kit from Incision?
I've got a VS4-10 chassis kit that I'll be putting TRX-4 Portal axles under, and I want to run an 11.4" WB because I have a Mighty FC body that I want to use. I'm already going to have to make a panhard and steering link, but not sure what other links I'll need to change to get to a 11.4" WB.
boldfin is offline   Reply With Quote
Old 07-03-2019, 05:35 AM   #8
11.4” WB. This is embarrassing, but I bought 3 fricken sets of 12.3” WB links to accomplish it though. Obviously the front kinks are the front links. For the rear I used the front lower links. And of course the front upper link in the rear, which is why the 3rd set of links was needed. So uh ya, I have several individual and one nearly complete set of links for sale
Old 07-03-2019, 06:10 AM   #9
Go Buckeyes!
B-MOW71's Avatar
Mog looks great on the VP chassis! Nice creative work on the mounts.
B-MOW71 is offline   Reply With Quote
Old 07-03-2019, 06:14 AM   #10
Hey thanks man.
Old 07-03-2019, 10:40 AM   #11
distinctive pd's Avatar
Looks great and now you’ve got proper clearance for portals too!!
distinctive pd is offline   Reply With Quote
Old 07-03-2019, 10:42 AM   #12
Damn you, as if I haven’t spent enough money on this one. You’ve really got me in the mindset now that I should put portals on this thing.
Old 07-03-2019, 11:23 AM   #13
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Clean execution on the conversion, not a simple one to knock out.
Harley is offline   Reply With Quote
Old 07-03-2019, 11:27 AM   #14
Awesome thanks man. Btw, dig the YouTube channel. Keep up the good work.
Old 07-03-2019, 04:00 PM   #15
So I started my conversation as well, coming along nicely and appreciate the pictures and your take on the mods to get it fit up.
I’ll get a thread going when I get a little further along.
I am using the VP portals and liking the results so far!
Old 07-03-2019, 10:50 PM   #16
I almost did the same thing. (I'm kinda new to all this). But then I stumbled across Hardcore RC https://hardcore-rc.ecwid.com/Axial-UMG10-c34952358
He sells complete link sets specifically for the UMG10 in 11.4" and 12" WB.
I just bought the 11.4" WB set. We'll see how those work out.
Old 07-19-2019, 05:23 AM   #17
VP chassis Conversion was a success with the VP portals as well! Super happy with the results!
Old 07-19-2019, 07:01 AM   #18
Wow man that looks awesome! Wish I had your detailing skills. When you get a chance would dig seeing under the body and the portals.
Old 07-19-2019, 04:45 PM   #19
SUPER-nice Moggie!
Lovin' the Euro-spec sponsorship decals...
durok is offline   Reply With Quote
Old 08-11-2019, 12:20 AM   #20
Siggy's Avatar
AWESOME Project! Inspirational!
NOW Thinking of a UNIMOG Dream Build.
NEW VS4-10 Pro Chassis to mount New VFD Tranny
Unimog Body
NEW VFD Transmission with New VFD Dig
Vanquish Portal Axles
RC4WD Humvee 1.9 Aluminium Beadlock
UMG10 Tires & Foams
Siggy is offline   Reply With Quote
VS4-10 Chassis Kit (Unimog) - Similar Threads
Axial blazer VS4-10 Chassis Kit build roadrashracing Axial SCX10 II 23 06-02-2019 04:36 PM
Now In Stock - New Vanquish VS4-10 Chassis Kit RPP Hobby RPP Hobby 0 05-24-2019 01:32 PM
Pre-Order Now - New Vanquish VS4-10 Chassis Kit RPP Hobby RPP Hobby 1 05-20-2019 04:31 PM
