03-13-2020, 09:23 AM | #81 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Jato the Ultra
I like the poop brown! Reminds me of a baseball glove. But I second Jason’s recommendation. I always hit the interior with a quick matte and it takes the shine out and makes it look more like fabric/leather. PFE |
03-13-2020, 09:55 AM | #82 |
| Re: Jato the Ultra
I also agree on using a flat clear. I use the Tamiya PS55 Flat clear on all of my interiors. |
03-13-2020, 10:07 AM | #83 | |
| Re: Jato the Ultra Quote:
Castle got back to me and said they just started making a new batch of the ESC's so it will be 1-1/2 to 2 weeks which is fine. Your interior looks great! I agree with all of you that Tamiya matte clear looks great. My LHS doesn't carry it and I often forget to order this paint with other orders. Buying it online, all by itself, is outrageously expensive. | |
03-13-2020, 10:09 AM | #84 | |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
I feel you on that. I just ran out and will likely order some “just in case” with my next parts order. I like to keep it on stock. Sent from my iPhone using Tapatalk | |
03-13-2020, 10:24 AM | #85 |
Rock Crawler Join Date: Jan 2012 Location: Vitoria-Gasteiz
| Re: Jato the Ultra |
03-13-2020, 10:32 AM | #86 | |
I agree with buying it online. It is outrageous! It was cheaper for me to have LHS order it! I usually try to keep two cans on my shelf at home at all times. | |
03-13-2020, 10:54 AM | #87 | |
I used to hate Castle products, but they have changed a lot for the better over the years and now I'm a huge fan. They also have great customer service. What other big name brand will answer questions on this forum? You also get email responses the same day in most cases. The issue I had with this ESC is a fluke. It's the first time I've had a problem with a Mamba X ESC. I do like HobbyWing as well though so you should be happy with that system. | |
03-13-2020, 11:24 AM | #88 | |
I wanna be Dave Join Date: Sep 2019 Location: US
The person I was speaking with not only spent the time to walk me through everything (even he was initially baffled as to what was causing problems, until the Quick Connect problem was finally realized), but he even started on the line until I was able to get the throttle's end-points properly set, so as to get the deadband down to 0.025ms. These guy are patient (unlike HW support), knowledgeable, and are TRULY interested in helping their customers get the most out of their products. Working in the service industry, if I could tip them, I would. ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
03-13-2020, 04:52 PM | #89 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
03-13-2020, 05:00 PM | #90 | |
Hey our memories sound similar! | |
04-06-2020, 08:09 AM | #91 |
| Re: Jato the Ultra
The replacement Mamba X came in from Castle so that restarted this build. They even included the XT60 connector from the ESC that I sent back. On this build, I am going to use a peasant's device - a BEC - because the Sfeer servo that I am using isn't the quickest or strongest on 6.0V. So I'll be setting this at 7.4V to max out the Chinese servo. I mounted the ESC in this orientation so that wires would clear the interior. I'm glad I took the time to check the clearances before sticking it to the chassis. I am jealous of those of you who have the talent for clean wiring. I do not. Even when I try it seems like the wires just don't line up to make clean bundles. So I end up with a rats nest like this! The Castle B-Link is just temporary. I'll remove that after the first trail run or so when I'm happy with my settings. I'm going to have to remember to get this truck too wet or I'll have to come up with another receiver box plan. Or maybe I'll give in and put everything in the fuel cell eventually. I decided to not use the stock fuel cell/receiver box because it's at the rear of the chassis and I didn't want to put servo extension on everything. I wasn't sure what to do with the long receiver antenna so I zip-tied a piece of antenna tube to the chassis. The antenna takes up the entire length of the tube so it won't easily slip out. In these photos you can also see the battery stop that I designed and printed. I wasn't confident that one strap was going to hold the battery in place. I also replaced the screws that attach the metal side plate to the chassis which is under the battery. I figured button head screws would be safer for the battery than cap head screws. The rear battery tray is very nice, but if you are using the dig you have to put the battery on the floorboard. For the side-mounted battery, the only provision you get from Vanquish is a single strap to hold the battery. You could use a second battery strap, but there's no slot for it cut into the sheet metal plate. It felt like spring this weekend so that gave me some time to paint on Sunday. I decided to try Tamiya's Dark Metallic Blue PS-59 backed with Gold PS-13 and then Duratrax Base Cover Black. I may never buy another uncut body again. Pre-cut bodies are so damn nice and cut out so much work! You can tell I haven't painted in a while because I washed the body and was all ready to spray it. Woah I need to apply the masks first. And then I applied the first mask sticker on the outside of the body! Doh! WTH are you doing?! Good think it was the smallest of the bunch - the taillight - so it came off easily. Freaking newb mistakes! It's a little dark, as expected, but I really like it. It is going to need an accent color though. I'm thinking about a white stripe. For the grille, I'm thinking about painting it silver or maybe even white. I'm leaning towards silver though. I think Molotow chrome would be great if I had somebody to airbrush it for me. What do you guys think? I particularly like this shot. It reminds me of back in the day when I was a kid and my dad would do body work on cars. All the parts and accessories are removed from the body so you have just the sheet metal. To me, the body looks like a sheet metal shell in this photo and I think it's cool. Last edited by JatoTheRipper; 04-06-2020 at 08:28 AM. |
04-06-2020, 08:54 AM | #92 |
| Re: Jato the Ultra
I had similar thoughts about the last picture when I was it on it on Instagram. Has a great, WIP in the field, nearing the light at the end of the tunnel, type of vibe. Really digging this color too! Will be a great combo with the interior color you chose. Nice work What voltage are you running your steering servo at? I think the 555 is 7.4v preferred as well, if you wanted you could likely ditch the bec and run the dig and steering servo through the mamba x internal bec. |
04-06-2020, 09:55 AM | #93 |
Rock Crawler Join Date: Jul 2012 Location: In a van down by the river
| Re: Jato the Ultra
I am digging that paint color! Nice update too!!! Cheers, Doc |
04-06-2020, 10:46 AM | #94 | |
I'm also thinking maybe making the top white or even just flat clearing over it. It's a Sfeers servo meaning it's from China. It's not branded Reefs, but I'd be shocked if they aren't the exact same servo. I am running it at 7.4V from the BEC. My FlySky receivers can't take more than 6.0V and that's the only reason I'm using an external BEC. Thank you! | |
04-06-2020, 11:11 AM | #95 |
| Re: Jato the Ultra
That looks like a BS6 receiver? If so those can handle higher voltage, up to 8.4v Specifications of the Receiver: Model Name: FS-BS6 Channels: 6CH RF range: 2.408-2.475 GHz RF channel: 135 RX sensitivity: -92dBm 2.4 GHz system: AFHDS 2A Modulation type: GFSK Power consumption: 4.0-8.4V DC Dimension: 30* 22* 16mm Weight:8g |
04-06-2020, 11:22 AM | #96 | |
On the website it says: Power: 4.0-6.5V https://www.flysky-cn.com/bs6-canshu But in the manual (page 17) from the same website it says: Power input: 4.0 - 8.4V https://static1.squarespace.com/stat...l+20171219.pdf | |
04-06-2020, 11:27 AM | #97 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Jato the Ultra
Ver' purty!! White stripe - yes Chrome grille - yes Clean up wiring - yes Have I ever masked the outside of a light area - yes |
04-06-2020, 12:38 PM | #98 | |
04-06-2020, 12:48 PM | #99 | ||
04-06-2020, 01:10 PM | #100 | |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
I think some white would really help it pop. | |
Tags |
origin, ultra, vanquish, vs-10, vs410 |
Jato the Ultra - Similar Threads | ||||
Mr Hydes >>ULTRA CUSTOM FAB ULTRA 4 BUILD<< | Mr Hyde | 2.2 Scale Rigs | 98 | 06-07-2014 11:58 PM |
Jato? | mike | Tamiya TLT Crawlers | 6 | 08-17-2005 07:46 PM |
