Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Fix for rear axle shaft slop
Old 02-19-2020, 10:26 AM   #1
Default Fix for rear axle shaft slop
Not sure Vanquish will send me any parts since I purchased my Pro kit from a member here, what is the solution to correct the slop in the rear ended that causes the hex pins to run against the lock outs?
jason02ws6 is offline   Reply With Quote
Old 02-19-2020, 10:43 AM   #2
Default Re: Fix for rear axle shaft slop
The fix is some axle spacers.
I'm sure Vanquish would send them if you email support, they asked me for the serial number of the kit and the address where to send the parts. If the previous owner never requested the shims, I don't see why you couldn't get them.
svt923 is offline   Reply With Quote
Old 02-19-2020, 12:27 PM   #3
You happen to know what size those spacers are?
Old 02-19-2020, 12:39 PM   #4
Never measured them but I would guess somewhere around 5x7x1.5mm.
Old 02-19-2020, 01:13 PM   #5
When I got me shims from Vanquish I emailed a picture of the pin rubbing and they sent me out the shims. No serial number just asked for an address.
carpetfuzz17 is offline   Reply With Quote
Old 02-19-2020, 01:23 PM   #6
Good to know. Thanks! I sent an email to them last night before posing this but wanted the feedback from this community as well in case this is something that is a simple fix. It would be awesome if they helped me out but I wouldn’t be upset in the least if they didn’t. I may have some spacers in my parts bin to quickly take care of this myself.
Old 02-20-2020, 10:47 AM   #7
Michael fromVP responded this morning and asked for my address and serial number. Got a following up email minutes after sending him the requested info with a tracking number! VP kicks some serious ass in the customer service department!
Old 02-20-2020, 08:40 PM   #8
Got impatient and managed to find some old bushings that I replaced with bearings while building a Slash drag car. I had to file them down a bit to fit but they worked out!
Before and after
Fitment
Fix for rear axle shaft slop - Similar Threads
Berg Inner Axle Shaft Fix Cruzin Illusion EnRoute Berg 22 05-06-2020 07:18 AM
Top shaft slop, transmission and diff graunch... easy fix. Dbx Axial SCX10 II 13 06-23-2017 08:27 AM
Rear Axle Shaft Slop monkeyracing Tamiya XC/CC01 2 12-17-2012 04:11 PM
Fix your rear axle slop on the super cheap! mdchris Axial XR10 14 03-08-2012 10:42 AM
Rear axle shaft slop? ittybitty Axial XR10 3 09-12-2010 11:02 PM
