05-24-2021, 06:41 PM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Twin Lake
| Forcing a 550 can Holmes motor in a VFD
Didn't know a 550 can motor doesn't fit a VFD transmission until it didn't fit putting the trans together. The Holmes trail master was 2mm to long, seems like a oversight on Vanquish part not to have a 550 fit but what ever. I decided to grind the back of the motor to see if it would fit since I didn't need that much more room. Hard to see in the pic but there is just a hair bit of space and the motor can be adjusted without any binding. Haven't run it yet so I'm not sure if there will be some hidden side effects.
05-24-2021, 08:41 PM | #2 |
Pebble Pounder Join Date: Mar 2020 Location: Maine
| Re: Forcing a 550 can Holmes motor in a VFD
My favorite posts on RCC are the ones where people are solving problems created by manufacturers oversites. I hope it works out for you. I went though the same issue with my VFD Capra build when I tried to put a Fusion motor in it which is 550 length. I ended up adding 10mm spacers to the standoffs between the VFD motor plate and the gearbox and making a 10mm longer top shaft out of 5mm chromoly rod. I only have pretty basic tools, no machinist stuff, and the only specialty tool I needed to buy was a v-drill guide for drilling the cross pin holes in the shaft and a M4 die for the threads on the spur gear end. With the extra space I can fit pretty much any 550 can motor now. I apologize for the picture. For some reason it's getting rotated when I post it here. Last edited by mjensen; 05-25-2021 at 08:26 AM. |
05-25-2021, 08:49 PM | #3 | |
| Re: Forcing a 550 can Holmes motor in a VFD Quote:
Great job on extending the transmission! I went on a 3.5 trail run with it today without any problems with the motor, so I'd say that grinding the back off will be ok. | |
05-25-2021, 09:11 PM | #4 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
So I can say that if you remove the red cap off the fusion, and trim a small piece of ribbing on the vfd, it will fit in there no problem.
05-26-2021, 04:28 AM | #5 | |
I had heard that but there is one component of the motor controller that looks to have a thermal pad on it and it rests against the aluminum end cover. I assumed the cover was acting as a heat sink to help cool the electronics and with reports of the Fusion running warm I was afraid that removing the cover might make it run hotter. Maybe that's not the case. | |
05-26-2021, 04:34 AM | #6 | |
That's great that it worked out. The simplest solutions usually turn out to be the best. I have a bad tendency to overthink things and end up making problems worse. | |
05-26-2021, 06:53 AM | #7 |
That could be the case, and that solution obviously doesn’t help if you want to run most any other 550 length motor. I agree with you guys, seems a real shame they didn’t design in a little more room... I’ll report back if I overheat... I’m pretty easy on stuff, so I’d be surprised if anything happens. But you may be right. |
Forcing a 550 can Holmes motor in a VFD - Similar Threads | ||||
550 12t 5-slot motors: Holmes Hobbies Crawlmaster Sport vs. Surpass Hobby | donaldsneffe | Electronics | 21 | 08-15-2021 03:29 PM |
