05-22-2022, 06:53 PM | #1 |
Newbie Join Date: May 2021 Location: Helena
| Dravtech
Got the Incision shocks built for the Pro, and already noticing a smidge of leakage down the rod on one of them - and it seems like a good excuse to give the Dravtech's a try finally. I'm assuming the 96mm eye-to-eye is the proper choice on the Pro? What springs and oil weight is everyone using for these shocks? Worth adding the 3mm spacer etc? I also have some new SSD 90mm shocks in the package I may try, but want to give Dravtech a shot after seeing so many folks praising them. Was also tempted to build some 90mm S8E shocks using the new aluminum parts and hard anodized shock body from Vanquish, but that's pushing a $150 for a set of 4...ouch. |
05-22-2022, 06:56 PM | #2 |
RCC Addict Join Date: Mar 2019 Location: Hemet
| Re: Dravtech
I run dravtech’s on my pro, they’re built with a 6mm spacer under the piston like he shows in the video. Making them ~90mm eye to eye. They’re great, I run dravtech’s on a lot of my rigs. For the pro I run it with soft springs in the front and medium in the rear if I remember correctly. Sent from my iPhone using Tapatalk |
05-22-2022, 07:23 PM | #3 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: Dravtech
I despise vanquish shocks. I only run dravtechs now, because of their simplicity. I'm sure you can build big bores, or element shocks in a similar way that are just as good... but I've had zero problems with the 4 sets of dravs I've built. Both types of vanquish shocks were garbage.
05-22-2022, 07:38 PM | #4 |
| Re: Dravtech
I appreciate the feedback ya'll, the S8E on the Phoenix seem to be holding oil (for now) but I don't trust the Incisions on the Pro. Def. going to order up the Dravtech's this evening. Is everyone running them upside down on the VS4-10's? Edit: ordered a set up with the 1/4" spacers and went mediums for both front/rear as the softs are OOS. Looks like the Losi Mini-T springs work as well, so may order some to try. While I wait, I'll either steal the GTS shocks off one of my TRX-4's, or build the SSD's to see if they hold oil. Last edited by Ty89m; 05-22-2022 at 08:12 PM. |
05-22-2022, 08:03 PM | #5 | |
| Re: Dravtech Quote:
I run them upside down on everything lol I also modded some s8e’s total length when done is 84mm using dlux zero preload spring buckets and springs. I’m with Dred805, I’ve got at least 6 sets of dravs with zero issues. Sent from my iPhone using Tapatalk | |
05-23-2022, 06:47 AM | #6 |
| Re: Dravtech
I too run them upside down. They fit better on the PRO if they are upside down. No trimming needed on the stock plastic shock towers and they fit better at the axle. I did have the Dravtechs on my PRO at first, but ended up switching them out to a set of Traxxas GTS shocks. IMO the Dravtechs work better on lighter rigs. My PRO is a heavy pig! Now my orange Dravtechs that were on my PRO now live on my GSpeed V3 build. They feel and work so much better on this lighter rig. Also have a set of Dravtechs on my GSpeed V1-C1. |
05-23-2022, 11:57 AM | #7 |
| Re: Dravtech
I do have a set of GTS shocks laying around I can try - as I have a feeling my Pro will be on the heavier side as well ha! For those mounting Dravtechs in the upper link mount on axles, do the pivots balls fit? My SSD lower pivots (and the GTS) are far too wide to fit in the upper mount area on the machined axles. I tried swapping the Incision balls into the other shocks, but the ball is smaller in diameter, so have a ton of play. I could grind down the SSD balls and make them fit, or mount like B-MOW71 and mount to link mounts. |
05-24-2022, 06:52 AM | #8 | |
| Re: Dravtech Quote:
As for the pivot balls, I don't believe I have tried others. I mounted my shocks on the link mounts because it was easy to do and it lower the ride height a smidge. | |
05-24-2022, 12:30 PM | #9 |
| Re: Dravtech
Yup, noticed that this morning while I was installing the front axle. Little Dremel action made quick work of that. GTS shocks seem to be a great solution - though still looking forward to seeing how the Dravtechs work. If I don't end up using them on the Pro, I'll find a use for them eventually Thanks for all the help! |
Dravtech - Similar Threads | ||||
Dravtech Shocks? | cloudswimmer | RC4WD Bully | 8 | 12-14-2020 11:18 AM |
Dravtech shocks | DKOR | Axial AX-10 Scorpion | 2 | 04-11-2018 10:54 AM |
