Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vanquish Products VS4-10 Origin
Thread: Phoenix Servo Fitment
Old 04-03-2023, 02:14 PM   #1
Default Phoenix Servo Fitment
I finally decided to put the electronics in a Phoenix portal that I built over a year ago. When doing this I found that the Holmes Hobbies servo that I purchased for the steering will not work. It binds on the chassis in 2 places. A Reefs servo I had works as it should. Anyone else experienced a Holmes servo not working in a Phoenix?
sherbs is offline   Reply With Quote
Old 04-03-2023, 03:13 PM   #2
Default Re: Phoenix Servo Fitment
I’ve had that issue with an shv800 and vp clamping horn.
I believe the shv650 and maybe the 500’s are a tad longer and don’t have the issue anymore.
Which servo did you have?
One could argue that the servo horn is to blame (at least in my case)… but I like using the vp horns.
twade984 is offline   Reply With Quote
Old 04-03-2023, 03:58 PM   #3
I have a SHV500 that I purchased at least a year and a half ago but never opened it until now. i have a Phoenix Straight that is unbuilt, hate to order a Holmes for that one and find out it will not work also.
Old 04-03-2023, 04:32 PM   #4
My SVH800 Did the same thing, using a VP horn. I filed the end of the horn down just enough so it clears. No issues as of yet
Damion10 is offline   Reply With Quote
Old 04-03-2023, 05:21 PM   #5
SHV500 v3, or shv500lp?
You could always just use a different servo horn?
Old 04-03-2023, 05:36 PM   #6
It is the SHV500LP. Anyone find a servo horn that will work?
Old 04-04-2023, 08:21 AM   #7
Sand down the mounting surface on the servo mount. I took about 2mm off which basically levels the mounting surface with the notch between the screw holes. The Holmes SHV800 and 500V3 clear easily with the Vanquish horn after that.
svt923 is offline   Reply With Quote
Old 04-04-2023, 02:03 PM   #8
Thanks!
Old 04-10-2023, 02:45 PM   #9
I've got one of the SHV800's in both my Phoenix and my Ultra but used a 500v3 in my Ultra originally. I would follow what @SVT923 said and shave the mount to make it work.
Lashlee is offline   Reply With Quote
Phoenix Servo Fitment - Similar Threads
What Overdrive Servo for Phoenix? BLUJEEP Vanquish Products VS4-10 Origin 11 03-13-2023 05:49 PM
Reef's 99 Micro Servo for Dig - fitment? boldfin Axial Capra 10 05-03-2020 03:43 PM
Steering Servo fitment shodog Axial SCX10 II 0 07-18-2018 08:17 AM
Servo fitment issues... Drm31078 Axial RR10 Bomber 11 01-16-2017 04:53 PM
Servo horn fitment? cheapjeep2 Losi Mini-Rock Crawler 3 12-30-2013 06:57 PM
