11-23-2015, 10:07 AM | #1 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
| Ascender Servo Mount Pics/Info Request
Guys, I'm building a rig using Ascender axles. I am trying to get the steering geometry correct and I end up with massive bump steer. I need to know about how high the stock Ascender servo horn is above the axle. Also about how far behind the axle the servo shaft is in a top-view sort of way (or bottom view). Any info would be great! |
11-23-2015, 11:14 AM | #2 |
| Re: Ascender Servo Mount Pics/Info Request
I don't have the info handy at the moment, but CMS with the servo horn swinging that way is no good, turn the servo mount like Vaterra stock. |
11-23-2015, 11:29 AM | #3 | |
| Re: Ascender Servo Mount Pics/Info Request Quote:
This axle would be excellent with a servo on axle mount. | |
11-23-2015, 01:15 PM | #4 |
Good. I like mine on Ascender frame with the stock CMS, but it would be nice to have servo on axle mounting plate as option especially when using with other chassis such as the G-Made Sawback that looks like what you're using. Hello, SSD? EDIT: Anybody else have dimensions handy? |
11-23-2015, 01:21 PM | #5 |
I can check dimension later for you, but I have pics of my front axle with steering in my Ascender thread posts # 156 and 184: Natedog's Vaterra ASCENDER The panhard is located approximately halfway between servo output shaft and the end of servo horn (draglink mount hole) slightly closer to the servo output shaft. HTH |
11-23-2015, 01:27 PM | #6 | ||
Yes, I am putting these on the Gmade GS01 chassis, but its the Komodo truck, not the Sawback. | ||
11-23-2015, 02:04 PM | #7 |
4 link and chassis mount servo will pretty much always have bump steer. That's why you want a panhard bar, as it controls the movement of the axle in a similar arc the steering link moves. And yeah, the servo horn should be horizontal not vertical.
11-23-2015, 02:32 PM | #8 |
| Re: Ascender Servo Mount Pics/Info Request That's good input. I hate to admit that I did not know that. I thought panhard just controlled the lateral movement of the axle, like the v shape of the top links does.
11-23-2015, 03:53 PM | #9 |
| Re: Ascender Servo Mount Pics/Info Request Good catch, I should have looked closer at his link setup and yes it will! |
Ascender Servo Mount Pics/Info Request - Similar Threads | ||||
My servo winch mount (detailed pics) | jrowles91 | Axial Wraith | 5 | 04-18-2013 10:27 PM |
Just bought an AX10, info request | Josh_Br | Axial AX-10 Scorpion | 8 | 12-24-2011 06:58 AM |
Servo mount pics | D-ran83 | Losi Micro-Rock Crawler | 5 | 03-27-2010 11:47 AM |
LOSI Carbon Fiber servo / lipo mount - any PICS with full size servo? | mascman | Losi Mini-Rock Crawler | 10 | 12-16-2009 08:35 AM |
