Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Ascender RTR
Old 12-14-2014, 02:35 PM   #1
Default Ascender RTR
I like the look of the ascender but it sits a little too high. Can it be easily dropped to make it look more scale?
jwalker497 is offline   Reply With Quote
Old 12-15-2014, 01:41 AM   #2
Default Re: Ascender RTR
Yes it can, very easy. You can lower both the suspension and also the body. I run my blazer fairly low, it looks more realistic and functions better.
I mounted the body so that the grille is just above the bumper. Then adjusting the spring preload to get the desired height.
Volvospede is offline   Reply With Quote
Old 12-15-2014, 03:37 PM   #3
How do you lower the body
Old 12-15-2014, 04:04 PM   #4
The posts have plenty of adjustment holes in them and are held in by screwed pins similar to the Axial drive shaft pins.
M1tch is offline   Reply With Quote
Old 12-16-2014, 04:59 PM   #5
I assume you had to trim the body? If so,how much?
racenut123 is offline   Reply With Quote
Old 01-07-2015, 10:23 PM   #6
Also curious about the trimming
Old 01-07-2015, 10:31 PM   #7
Put the truck on the table up side down and look underneath and see where the bumpers rubs against the body, mark it with a sharpie and dremmel out the places needed, you can also use lexan scissors or hobby/crafts knife. Just do some trial and error, its basicly pretty simple
AngelowDoom is offline   Reply With Quote
Old 01-08-2015, 11:36 AM   #8
It is super easy to do, and it makes the truck look a lot better. Mine is mounted nice and low with the grille right above the bumper just like a real Blazer. I'm not sure why so many people have been afraid to cut a little lexan and mount the body this way.
metalry101 is offline   Reply With Quote
Old 01-08-2015, 11:44 AM   #9
Yep, easy to do. Did mine the same way after looking at my 1:1 blazer. Front bumper is just below the grill and the rear bumper is just below the rear tailgate. You just notch out a little to clear the bumper mounts, about 1/4". I cut the front of my body at an angle to match the front bumper but the rear fits just fine.
If I remember right, I mounted the front body post with 11 1/2 holes showing and the rear with like 13 1/2 or 14 1/2 showing.
Here's a good side shot before I trimmed the front of the body to match the bumper.
Crusty Old Shellback is offline   Reply With Quote
Ascender RTR - Similar Threads
So how does every one like their Ascender? skybolt Vaterra Ascender 27 06-28-2015 04:54 PM
Better Value? Ascender RTR or Deadbolt? R/CMaxximus5.0 Vaterra Ascender 14 12-08-2014 11:54 AM
Ascender RTR svt923 Vaterra Ascender 13 11-09-2014 11:23 AM
