01-08-2015, 12:58 AM | #1 |
Newbie Join Date: Dec 2014 Location: Northern,IL
| Dang torque twist!
Does anyone have some suggestions on how to reduce it? The JC Auto Design upper link mounts didn't do anything, I actually think they made it worse. Thanks: Steve |
01-08-2015, 03:07 AM | #2 |
Pebble Pounder Join Date: Apr 2013 Location: Germany
| Re: Dang torque twist!
Of course, the RULR didn't get rid of the torque twist of my Ascender, as this is impossible. But it reduced it to the point that the body still tilts, but all wheels stay on the ground. Other than that, you could try to add more pre-load to the rear left spring or use a harder one. More damping would also reduce the effect a little, but both measures certainly have an impact on suspension performance and I try to stay away from that. |
01-08-2015, 11:45 AM | #3 |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
If you check out my build thread you can see how I mounted an Axial Wraith sway bar to the truck. It has definitely helped. I'm still tuning it with bar thickness and whatnot, but it is an easy mod that looks super scale (when paired w/ the links and coilovers at least) and massively improves performance.
01-08-2015, 11:55 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Middleburg Florida
The 2-1 axle gears suck, they are causing the TT much more so than the 3-1 or 3.3-1 axial gears do. A couple guys here are running the ascender, they preload for forward but downhill the trucks lean very hard the other direction. That crappy axle ratio is the only reason I don't have one. Good luck on getting your TT under control.
01-08-2015, 01:56 PM | #5 | |
Pebble Pounder Join Date: Aug 2013 Location: near jax
| Re: Dang torque twist! Quote:
01-08-2015, 03:47 PM | #6 |
Rock Stacker Join Date: Feb 2005 Location: Medford
X2 on the sway bar. I have one on the rear only, problem solved. The RULR things were a waste of $$, just flexed and moved all over the place.
01-09-2015, 12:54 AM | #7 |
Newbie Join Date: Nov 2014 Location: Finland
If the swaybar is thick enough to really limit the TT, how much it will limit the suspenision movement in rough terrain? do you still get full flex with the swaybar?
01-09-2015, 04:28 AM | #8 |
Newbie Join Date: Apr 2007 Location: france
A small Slash rear sway bar and the shocks and links moved outward on the rear axle: very pleased with the result. |
01-09-2015, 07:01 AM | #9 |
| Re: Dang torque twist! |
01-13-2015, 02:27 AM | #10 |
Does anybody have any before and after flex pic's or video's with rear swaybars?
01-13-2015, 10:32 AM | #11 |
Newbie Join Date: Apr 2012 Location: Lynwood
01-13-2015, 09:16 PM | #12 |
It does limit travel quit a bit, but I feel it is worth it for the stability. I am working on a way to have a servo operated sway bar disco, so hopefully I will have the best of both.
01-13-2015, 10:33 PM | #13 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
For your RULRs, when did you purchase them? I made a running change to them that may help, but as has been stated, the 2:1 axle ratio is really to blame, and the RULRs only help to reduce the twist (their main feature is the better geometry for steeper climbs). If you have a set of the first version, I will gladly send out a set of the second version at no charge so you can try them out. Please send me a PM with your Paypal transaction number, and we can go from there. Thanks! |
01-14-2015, 01:03 AM | #14 |
I will try to make some swaybars from piano wire, couple different thickness / shapes. Hopefully when combined with soft enough springs i can still get maximum flex with reduced amount of TT. And when it is ready you will get pictures and video of how it works, even if it doesn't work! Edit: bought 1.0, 1.2, 1.5 and 2.0mm piano wire. Bent the first swaybar from 2.0mm and used original long springs without the short, soft spring on the top. This helped quite lot to the TT, but lost a little of the suspension travel as expected. i think next I'll put the short springs back to soften the suspension and make the swaybar even stiffer by making the shape little different. I believe that with correct combination the result could be really good. Hopefully I have time this evening to test this. Last edited by Volvospede; 01-14-2015 at 11:48 PM. |
Dang torque twist! - Similar Threads | ||||
help!-- Torque twist | Tom94offroaduk | Newbie General | 24 | 03-03-2011 04:46 PM |
Torque Twist | Swiss | Axial AX-10 Scorpion | 6 | 10-15-2007 01:12 PM |
Torque Twist | SeanD | HPI Wheely King | 20 | 06-07-2007 11:26 AM |
Torque Twist | John Deere | Tamiya TLT Crawlers | 31 | 04-13-2007 03:03 PM |
Torque Twist | drzjohn | Newbie General | 1 | 03-09-2006 11:13 AM |
