03-11-2015, 09:35 PM | #1 |
Newbie Join Date: Apr 2013 Location: San Antonio
| New Ascender
Just pulled the trigger on a new ascender and want to know what are the must haves. I read through a few of the the other threads but I'm looking for the most up to date info. Does the kit come with the HD gear? Have all the mistakes been fixed with the new kit? Looking at HH 27T (35T seams to be out of stock), is this a good motor? Looking to make it a 2 speed, what's the parts list needed and we're can I get the instruction to make the changes? |
03-12-2015, 10:22 PM | #2 |
| Re: New Ascender
Ordered some wheels but still can't decide ont he motor, what is everyone running?
03-13-2015, 04:10 AM | #3 |
Newbie Join Date: May 2006 Location: WOODBRIDGE
| Re: New Ascender
There are several options for motors for the Ascender. I run a 45 turn on 3s in one and the other I run a 17.5 unsensored system in. The 17.5 can be run on 2 or 3s. As long as you drive the truck like it was intended for you shoulded have any failers. I got my trucks when they first hit the hobby shops and have been driving then every weekend with zero failures. As for the 2 speed I never decided to go that route. I have a twin hammers which has basically the same transmission but is two speed and the shift servo set up can be a little bit tough. I didn't want to deal with it in the Ascender. I would recommend building the truck and driving it with the single speed to determine if you want or need the 2 speed. You can save that 60-70 dollars and put it somewhere else in the truck.
03-13-2015, 04:44 AM | #4 | ||
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: New Ascender Some do, some don't. Mine didn't (ordered right after Christmas), so I'd suggest ordering a pair to have on hand just in case. Same with the HD shafts. Both parts are cheap, and worst case is you'll have spares. The answer to that question is never no, regardless of vehicle or manufacturer.. Quote:
How to convert Ascender trans to a Two Speed This 2-speed is a bit more finicky than some others. I'm glad I did it, but I wouldn't recommend it right off the bat if you're new to kit building. You can always add it later. | ||
03-16-2015, 01:53 PM | #5 | |
Pebble Pounder Join Date: Mar 2011 Location: Florida Gulf coast
| Re: New Ascender Quote:
03-17-2015, 09:32 PM | #6 |
| Re: New Ascender Came in today!!!!!!!!!!!!!! Started on the transmission and noticed that the slipper plates were similar to my Team Losi Racing 22s, so......... ...I will be replacing them with these. They have more contact surface and will vent better. Also, the spur gears are the same so now you have more options. Last edited by adonis_mp; 03-17-2015 at 09:34 PM. |
New Ascender - Similar Threads | ||||
My ascender | Fatman489 | Vaterra Ascender | 2 | 01-26-2015 05:29 PM |
