06-22-2015, 03:06 PM | #1 |
Rock Stacker Join Date: Nov 2014 Location: Lake Charles
| Need help with new body on my Ascender
Anyone have a good source for body mounts to help me fit an Atlas body to the Ascender? I don't have problem with the RTR body it's just that there are a lot of red and white Blazers out there and I want something different. I have seen many different options out there for body mounts but don't know which would be the best set to get. Any help appreciate.
06-23-2015, 09:55 AM | #2 | |
| Re: Need help with new body on my Ascender Quote:
06-23-2015, 02:23 PM | #3 |
| Re: Need help with new body on my Ascender I decided to cut the body and find how far off it is. Natedog you are right, simply shorter straight posts will work. Sorry for my senior moment. So if anyone wonders if the Jconcepts Atlas body will work here it is. Turns out no special body mount needed. I really like this truck as it is so flexable on aftermarket upgrades. |
07-01-2015, 10:06 AM | #4 |
Update on the new body for my Ascender. I have almost completed the paint job, wish I was good at painting. I have some problems areas to fix but here it is. |
07-01-2015, 10:32 AM | #5 |
That came out good, like the color, looks like you painted the black bed liner and fender flares on the outside for that matte look?
07-01-2015, 11:35 AM | #6 |
Thank You Natedog. Yes I did paint the flares and bed on the outside with satin black. I meant to buy flat black but got this instead. We will see how well it holds up to trail runs. I'm going to do some scale additions to the stock body and swap back and forth. |
07-02-2015, 12:16 AM | #7 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
Dang that body is HUGE! That will definitely stand out in a sea of red and blue blazers!
07-02-2015, 10:58 AM | #8 | |
07-06-2015, 09:33 AM | #9 |
Well 2 lessons learned, Krylon Synergy paint for plastics is not recommended. I waited 5 days before trying to scrape off the poor masking errors. This paint refuses to dry completely to a hard finish. So I am unable to fix my fender flairs. Second painting on the outside of the lexan body is a bad idea.
07-07-2015, 10:33 AM | #10 | |
New outside paint! I like the color and shine better on the outside, not so overly glossy like inside paint and when it scratches you'll see the 'steel' underneath. | |
07-07-2015, 03:54 PM | #11 |
I should have used the Pactra or Tamiya lexan paint. I'm glad to hear you are having good results on painting on the outside. I wish I had a local hobby shop that I can buy things like this. My nearest LHS is 60 miles away. Lesson learned. Your outside paint job looks good. |
07-08-2015, 06:05 PM | #12 |
Sometimes you try stuff and it works out great, other times it's learning. As long as you're using lexan paint, wash the body like you would for a new paint job, and spray when the temperature and humidity are within range it should turn out well. Bummer about 60 miles to LHS. Thanks. It's good to have spare bodies and trail versus shelf bodies, you can buy another and try again. I want to get a Deadbolt body to outside paint for when I want a smaller beater body.
Need help with new body on my Ascender - Similar Threads | ||||
Ascender body on scx10 | 4X4 Freak | Axial SCX-10 | 28 | 03-10-2016 01:22 PM |
Ascender Body Swaps | jrkilburn | Vaterra Ascender | 3 | 12-30-2014 06:16 PM |
