07-04-2015, 02:17 AM | #1 |
Rock Stacker Join Date: Jun 2015 Location: K
| Ascender 2-Speed Linkage Idea
Just came across this picture while searching through a Twin Hammers thread. Figured you guys running the 2-speed trans setup in the Ascender might think it was cool. I'm guessing he set it up this way as a servo saver due to the bashing nature of the Twin Hammers. If I ever decide to run the 2-speed I might try this out and see how well it works. |
07-04-2015, 02:56 AM | #2 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
| Re: Ascender 2-Speed Linkage Idea
Wouldn't it slip in and out of gear? Or maybe it's just late and I'm not seeing how's it's suppose to work
07-04-2015, 07:49 AM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
It's common to use springs in a setup like that... the Traxxas Summit is build entirely like that for their gearbox and diff lockers, since you can't adjust the endpoints.
07-04-2015, 03:46 PM | #4 |
Newbie Join Date: Feb 2015 Location: UK
I've never had any trouble with the kit linkage or the shift servo in my TH or now my Ascender tbh. It's all about setting the end points correctly, & only shifting whilst the truck is moving. I only use a cheap Hobbyking $8 servo too.
07-06-2015, 11:58 AM | #5 | ||
| Re: Ascender 2-Speed Linkage Idea Quote:
Yes, if you setup correctly should not be any problems. Fullsize servo? Which one? | ||
Ascender 2-Speed Linkage Idea - Similar Threads | ||||
How to convert Ascender trans to a Two Speed | Rich Trujillo | Vaterra Ascender | 72 | 08-07-2019 12:03 AM |
two speed controler idea. | mike | General Crawlers | 21 | 02-28-2005 04:12 PM |
