08-24-2016, 02:24 AM | #21 | |
Rock Stacker Join Date: Mar 2015 Location: Turin(Italy)
| Re: Falken Jeep JK flatbed Ascender by NightRider Quote:
I will refine the shock setup when the car is done,It will be around 3,5kg(around 11,5 lbs) or a little more. | |
08-24-2016, 10:56 AM | #22 |
Very cool!
08-25-2016, 10:49 AM | #23 |
| Re: Falken Jeep JK flatbed Ascender by NightRider Thank you I finally received the transfer case,made of ABS mixed with aluminum powder. I built an adapler plate for the Vaterra skid made of a thick cabon fiber plate I have chosen this transfer case because it allows me to have a front Overdrive to help traction. Another advantage is that the rear axle has a reverse rotation so helps minimize torque twist. Obviously I will have to rotate the rear axle to change the wheel rotation sense. |
08-25-2016, 04:56 PM | #24 |
Newbie Join Date: Feb 2014 Location: Northeastern Ohio
Where'd you get that tcase
08-25-2016, 05:33 PM | #25 | |
Axial Racing - Shock Shaft 3x50 (2pcs) I really like this. Do you have eye to eye extended and collapsed shock lengths with this setup? | |
08-25-2016, 06:53 PM | #26 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
Man, you guys over in my mother land really got your stuff together when it comes to making custom parts! Really good idea for the transfer case, both the overdrive front and counter rotation for the rear! Can't wait to see if it really helps with torque twist. Great build! Ben |
08-26-2016, 02:30 AM | #27 | ||
I think they are the same of the link. I don't have the collapsed measure,but the extended eye to eye measure is 90mm Quote:
Nice to see an italian comment my work. I'm a little envious...I love USA,I made two long road trips in USA but I don't visited Maine yet. The transfer case comes from The Scaler Store,a very good custom shop here in Turin. My friend maxbonv use the same setup and it work very good on his full custom Ascender. | ||
08-26-2016, 04:23 AM | #28 |
I've got some inspiration from maxbonv and his builds. The scaler store you say huh? I'll have to check them out. I'm trying to get with Giuseppe Musumeci and see what he has for the ascenders but don't have Facebook so I'm having troubles with that. I tried to log in under a friend's name but couldn't find his store or products on Facebook. I've emailed him and heard back but don't know everything he offers. I'm looking to build a leaf sprung ascender and want his delrin leafs also looking to do motor forward so motor mounts and transfer case would be nice too. Keep up the good work! Ben |
08-26-2016, 05:24 AM | #29 | |
| Re: Falken Jeep JK flatbed Ascender by NightRider The Scaler Store - TSS Ripartitore Centrale ABS Reversibile Configurabile ARGENTO Quote:
Probably he follows Scaler&Crawlers forum in Italy. ;) | |
08-26-2016, 05:44 AM | #30 |
Not to have interference problems between the engine and axle I reconstructed the truss creating a low profile that moves the upper link attachment to the side |
08-26-2016, 09:41 AM | #31 |
Today is dedicated to fit the transmission. carbon fiber adapter plate mounting,all using stock chassis holes a second plate secure the other side The motor take place in the space cleared by the new truss Lower than this is impossible using the Vaterra transmission,the motor level is almost the same of a stock Ascender so the COG probably don't chancge much. I'm very satisfied....and using stock parts again. Last edited by The_NightRider; 08-26-2016 at 09:44 AM. |
08-28-2016, 04:35 AM | #32 |
A better picture of the motor positioning Now you can see why I moved the upper link. |
08-28-2016, 09:45 AM | #33 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Ernie, | |
08-28-2016, 11:41 AM | #34 | |
Quarry Creeper Join Date: Dec 2015 Location: Norway
08-28-2016, 02:29 PM | #35 | |
Ernie | |
08-29-2016, 03:11 AM | #36 | |||
But che choose was low motor positioning or a steep shaft. Obiouvsly I will do some seriuous tests to check reliability. I don't like cars that broke in the middle of the track. Quote:
I prefer cars with not too much shock travel,I don't like load transfer so I prefer to stay in the 90/95mm range. update yesterday I mounted the electronics(HH BR mini ESC) and tested the naked car. I'm very satisfied,It moves very well(in my backyard...),I have only to rebuild the rear shocks because have some years of work on their back. | |||
08-29-2016, 03:51 AM | #37 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
So I guess you have to mount the battery in the rear?
08-29-2016, 05:05 AM | #38 |
| Re: Falken Jeep JK flatbed Ascender by NightRider I will use a 2200mAh 2S battery,slim enough to stay under the passenger seat The other electronics take place under the driver seat,all to maintain a low CG. The hard part is to find a way to fix the body on the chassis but easily removable to change battery. I'm working on it.... |
09-05-2016, 03:41 AM | #39 |
First test of the car w/out the body. https://www.youtube.com/watch?v=u01Du1vyt6I It works!!! And it works wery well. Cantilever and shocks are very smooth,the HH esc/motor combo is like honey but very reactive(I use only 2s batteries) when you need power. Gearing and steering are ok,I've noticed a little torque twist but probablly will disappear when i fine tune the rear suspension. |
09-05-2016, 07:24 AM | #40 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Nice job! What tire are you going to end up with?
Falken Jeep JK flatbed Ascender by NightRider - Similar Threads | ||||
Upgrading the Jeep Wrangler Falken G6 | stonecold | Axial SCX-10 | 34 | 08-21-2016 10:08 AM |
Just a Falken Jeep | HDMM | Axial SCX-10 | 13 | 08-09-2015 06:34 PM |
