08-09-2016, 11:45 AM | #1 |
Rock Stacker Join Date: Mar 2015 Location: Turin(Italy)
| Falken Jeep JK flatbed Ascender by NightRider
Some pictures of the car that insipred me,a Falken concept shown at the 2012 SEMA. The car has a cantilever system I want maintain on the 1/10 replica. More pictures here 2012 SEMA Falken Jeep JK Wrangler Flatbed I don't want to bore you with the kit build,so.... Axles with GPM upgrades Chassis with aluminium skid plate The next step is build the cantilever system,so after some reasoning I remebered i have a car with push rod system that can work perfectly,the Vaterra Twin Hammers. I had som spare parts from the VTH because I switched to a front tower system,so I tried to fit the rocker arms and...it works!!! Let's twist!!! All using only stock Vaterra parts!!! If you want a cheap cantilever system that works perfectly(springs are right) find two VTH front shocks and rocker arms,drill two holes in the chassis and you are ready. In the next days I will start the body,using a plastic Jk body. Stay tuned |
08-09-2016, 11:50 AM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: Falken Jeep JK flatbed Ascender by NightRider
Yo, that's awesome... Can't wait to see how the rest of this goes. You set a pretty high bar right out of the gate.
08-09-2016, 12:27 PM | #3 |
| Re: Falken Jeep JK flatbed Ascender by NightRider X2, well said. Nice and clean with the shocks inside the frame rails. Last edited by Natedog; 08-09-2016 at 12:38 PM. |
08-09-2016, 12:32 PM | #4 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
Interesting concept. Any reason you chose to mount your cantilevers inside the frame rails?
08-09-2016, 12:55 PM | #5 |
| Re: Falken Jeep JK flatbed Ascender by NightRider Nothing else is going to go there. Why mount them outside and create potential clearance issues with tires and wheel offsets? This way it's wide open around the tire/flex zones.
08-10-2016, 05:20 AM | #6 | ||||
| Re: Falken Jeep JK flatbed Ascender by NightRider Quote:
But I've gained some experience with other cars I've built so I'm confident. Thank you for your support Quote:
In fact this is more a push rod system than a cantilever. Another strong point of the system is progressive like a rear suspension of motocross bike,so the suspension is soft at the beginning and progressively becomes harder. It's the first time I use this system so I'm curious how it works.... | ||||
08-10-2016, 06:30 AM | #7 |
Pebble Pounder Join Date: Dec 2015 Location: Edmonton
Subscribed !! looking forward to see how things go along, post a lot of pics.
08-10-2016, 10:46 AM | #8 | |
First work on the body... Obviously all the back will be flattened. I will fill the holes with body parts dissolved in acetone that act as "plastic glue"(it works ). Lateral panels will be rebuilt with forex/styrene and reinforced. | |
08-12-2016, 08:27 AM | #9 |
| Re: Falken Jeep JK flatbed Ascender by NightRider |
08-12-2016, 12:22 PM | #10 |
| Re: Falken Jeep JK flatbed Ascender by NightRider Tomorrow I will refinish with light sandpaper and soap water and drill the hole for the mesh grill. |
08-13-2016, 09:38 AM | #11 |
| Re: Falken Jeep JK flatbed Ascender by NightRider the grill shape is a little less complex than the original ;) |
08-13-2016, 11:02 AM | #12 |
08-14-2016, 05:09 AM | #13 |
08-14-2016, 01:56 PM | #14 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
I don't know how I've been skipping over this build. Now that I've found it, I'll be watching Love what you're doing here!
08-14-2016, 04:06 PM | #15 |
I have build envy for sure. It's coming along very nicely and I'm getting very excited to see the end. That rear suspension is still my favorite thing I've seen on RCC recently.
08-18-2016, 02:40 AM | #16 |
Sorry for no news this week,I'm in Amsterdam for a few days. When I,m back I my favourite shop will be open open so I can start the gearbox too ;) |
08-19-2016, 07:06 PM | #17 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
Could ya possibly give me the length of those shocks? The rear setup is awesome, so simple....
08-21-2016, 10:51 AM | #18 |
08-23-2016, 06:37 AM | #19 |
As I said before I want to use the pieces of the kit as much as possible, trying to improve the performance. The kit's shock absorbers are too long and have too much travel so I decided to modify them. Not wanting to cut and thread the original rods I took the rods by an axial (TIN covered) and I put the plates (I had to lower them of 0.3 mm) of the Ascender Then I shortened the body of a centimeter(thanks to maxbonv for the trick) To improve smoothness and prevent oil leakage I used the oring in Traxxas Big Bore rebuild kit. Work done, everything seems to work and the smoothness is excellent with a good hydraulic control. It remains to be seen whether the springs are right but the first dynamic test will have the last word. Last edited by The_NightRider; 08-23-2016 at 07:12 AM. |
08-23-2016, 09:33 AM | #20 |
Very nice shock mod, I would try using a soft upper (short) spring with that setup, but with heavier hardbody it might be perfect. This setup creates more preload on the shock springs, similar to where the adjuster collar is stock on RTR. |
Falken Jeep JK flatbed Ascender by NightRider - Similar Threads | ||||
Upgrading the Jeep Wrangler Falken G6 | stonecold | Axial SCX-10 | 34 | 08-21-2016 10:08 AM |
Just a Falken Jeep | HDMM | Axial SCX-10 | 13 | 08-09-2015 06:34 PM |
