Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Ascender
Thread: Stock tire wheel fitment
Old 08-17-2016, 07:58 AM   #1
Default Stock tire wheel fitment
Ok so I'm building a kit,don't want to glue to stock rims.got a set of steelies and rc 4wd proline rings...no dice.sooooooo what wheel is a for for this tire?thinking of just a axial 1.9 bullet hole.but don't need them if they will not work.
racer is offline   Reply With Quote
Old 08-17-2016, 08:25 AM   #2
Default Re: Stock tire wheel fitment
RC4WD steel rims are a beast with anything other than RC4WD tires but, it can be done. Freeze your tires over night and use an #8 or #6 bolt and nut in the center to tighten them with even pressure.
These are stock Vaterra TSLs on RC4WD steelies with the proline rings.
Hobbezco is offline   Reply With Quote
Old 08-17-2016, 09:42 AM   #3
I got Gear Head Trail Kings to fit ok. Bead is tight, but does work ok.
M1tch is offline   Reply With Quote
Old 08-17-2016, 10:01 AM   #4
Natedog's Avatar
I've done a few sets, they are not fall together easy, but they work. I used VP 1.9 internal rings, they are similar to the RC4WD blue Proline tire specific rings.
Old 08-17-2016, 10:18 AM   #5
Thanks guys,i found a post in the tire and wheel section for this...du......I'm just going to weight the plastics and glue these bad boys.my tf2 could use some proline meats on steelies.I'll just purchase a whole setup as I need them.thanks for ur help though.
Stock tire wheel fitment - Similar Threads
Newbie Tire Question - Moab XL Wheel Fitment Spark Plug Tires and Wheels 4 10-24-2009 04:33 PM
