09-04-2020, 12:07 PM | #1 |
Pebble Pounder Join Date: Jun 2020 Location: Baton Rouge
| True 1/10 scale?
So my coworker has a trx 4 bronco. I was truly surprised as to how much bigger the actual body was compared to my suburban. Side by side its much smaller than the trx4. So I guess my question is if the ascender is a true 1/10 scale truck? Sent from my SM-N975U using Tapatalk |
09-04-2020, 12:14 PM | #2 |
| Re: True 1/10 scale?
I wouldnt get too wrapped up in whats correct, just know sizes for whats called 1/10 scale are all over the place. If you want to check though find some measurements to compare and divide (the 1:1 numbers) by 10. Sometime RCs also class themselves as 1/8 scale simply because they use 1/8 scale sized components (not the body). |
09-04-2020, 12:23 PM | #3 |
I'm beginning to see that now. I thought some of the drag bodies were just large but compared to my dr10 and the trx4 is just smaller. Really its not a big deal but we were both kinda surprised looking at them next to each other Sent from my SM-N975U using Tapatalk |
09-05-2020, 05:58 AM | #4 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
You also have one of the most disproportionate bodies out there. They took a chassis that started out with a blazer body, then made a suburban body to fit that same wheelbase. A suburban has two more doors well, the 73-91 suburban a do, the 72 style like yours should only be a three door but I digress. and about a foot longer rear section than the blazer does so that’s why your body is so much smaller. The Vaterra blazer body actually works out to about 1:8.5 scale.
True 1/10 scale? - Similar Threads | ||||
True to scale 1:1 hyrax | Frank211 | Chit Chat | 14 | 04-02-2019 02:45 PM |
TRuE SCALE | Pointman | Scale Videos! | 9 | 03-10-2013 10:23 PM |
True 2.2 scale? | mhuffman_81 | 2.2 Scale Rigs | 34 | 04-14-2011 04:33 PM |
