03-02-2017, 12:52 PM | #1 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| K10 rear cage dimensions?
Can anybody tell me how wide the top bar is (where it meets the roof of the cab) and also how wide it is at the bottom? I'm building a hilux truggy out of a tamiya hilux shell, and I need to know if the K10 cage will work for me. Thanks! Also, I narrowed the axles a total of 12mm, am I going to have serious clearance issues with the tires and the side panels? Thanks again! |
03-02-2017, 06:23 PM | #2 |
| Re: K10 rear cage dimensions?
I can measure the cage for you later. Narrowed axles should be better for that, but I'm not sure what you're asking and for which body setup? |
03-02-2017, 09:52 PM | #3 |
6 3/4" outside to outside at top of cab 7 5/8" at bed level (height that spare tire bolts to) 7 3/8" at bottom cab to cage mounts Hope that helps. |
03-03-2017, 07:03 AM | #4 |
This is perfect! You are the man! I appreciate you doing this more than you know. Tonight I will measure my Hilux and see where we are at. Thanks!
K10 rear cage dimensions? - Similar Threads | ||||
rear shaft dimensions | jebster | Team Losi Comp Crawler | 2 | 10-15-2015 01:36 PM |
Hilux rear cab dimensions | jeepscx10 | Paint and Body | 0 | 02-04-2014 09:32 PM |
Honcho cage dimensions? | the_ghetto_rig | Axial SCX-10 | 1 | 07-15-2011 04:33 PM |
