03-17-2017, 06:53 PM | #1 |
Pebble Pounder Join Date: Jan 2017 Location: Boone
| Extending the wb4 wheelbase?
Hello all, Searching didn't yield any input on this question, so here goes..... I ordered a new body and a new set of tires for my ascender. From reading and looking at pictures of the body on a 12.3 wheel base I think I need to extend it around an inch, give or take, to keep from cutting into the doors on the body and help approach and departure angles. Making some assumptions, I would guess it would be easier to mover the rear axle. I would also like to make the top links slightly longer to tilt the pinion up slightly. My idea is to buy the correct length links for the current wheel base, without spacers, them use spacers to push out the wheelbase slightly for clearance. I don't think this small increase will affect how the shocks work, but does the drive shaft have enough travel? Any input would be very much appreciated... I couldn't find a tread on anyone doing this yet.... |
03-17-2017, 08:23 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
| Re: Extending the wb4 wheelbase?
Also, will tilting the top of the rear shocks forward help torque twist the same way out boarding them does?
03-17-2017, 08:59 PM | #3 |
| Re: Extending the wb4 wheelbase? I would guess it wouldn't help, as it would make them have less leverage on the axle. But just a guess. I think the reason out boarding them helps is because it causes them to bind slightly, not traveling in a straight line in relation to the axle movement, causing the axle to not move as freely. But again, just a guess as I haven't tried it.
03-17-2017, 09:04 PM | #4 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
You won't have enough driveshaft to move the rear axle rearward an inch. Your idea with the links should work fine. I'd just buy some solid steel or aluminum rod, cut to length, drill and thread and you'll have your links made up in one solid piece. While you're making links, definitely rotate the rear axle so the pinion angle is better. Might as well relocate the upper rear link front mount upward like we've all done to help with torque twist. Doubt the angled shocks will help with torque twist. Probably be worse because of the angled setup, the spring rate will be softer since they aren't acting straight up and down but now on an arc as well. Ben |
03-17-2017, 09:41 PM | #5 |
X2, Ben nailed it. You can extend rear links 12mm more like I did, more than that and you'll have to buy or fab rear drive shaft. Ime laying rear shocks forward doesnt climb as well. Outbaording front and rear shocks helps with tt a lot, because axle has less leverage on them. I've only outboarded rear so far but Rockhugger has done both and front tires barely touch shock springs if that. Last edited by Natedog; 03-17-2017 at 10:21 PM. |
03-18-2017, 05:34 PM | #6 |
| Re: Extending the wb4 wheelbase? Thank you for the good ideas. I doubt I can outboard the front shocks since I am running the Twin hammers shocks. They are slightly larger, so it looks like they will rub.
03-18-2017, 07:37 PM | #7 |
You're welcome, try it and see.
Extending the wb4 wheelbase? - Similar Threads | ||||
Extending the scx10 wheelbase. | Paul1234 | Axial SCX-10 | 7 | 09-16-2013 10:52 AM |
Extending The Wheelbase Qs | EEM-CrawlinMachine | 1.9 Scale Rigs | 2 | 02-02-2011 05:20 PM |
I am extending my wheelbase and need drivelines | ScaleReady | Losi Mini-Rock Crawler | 8 | 03-25-2010 09:32 PM |
Extending the wheelbase of a Creeper by 1” | shambrick | Venom Creeper | 2 | 02-15-2010 04:41 PM |
Extending the wheelbase | Got Rocks? | General Crawlers | 7 | 10-05-2005 08:45 PM |
