01-13-2017, 06:55 PM | #1 |
Quarry Creeper Join Date: Aug 2016 Location: Or-eee-gun
| OnT's K5 Blazer build
After ordering my kit months ago. I finally got around to begin the build. I'm starting to think that Friday the 13th wasn't the right day. Of the 6 screws required to seal up the transmission, 3 of them stripped. 2 M3 10mm on the motor plate and 1 M3 25mm on the back of the case. I don't feel that I over exerted the driver. From the get go they all seemed a very tight fit to the tranny case. I think a screw kit will be in order for any further issues. Which I hope there are none. |
01-14-2017, 12:18 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
| Re: OnT's K5 Blazer build
Well, I'm guessing things will only get better from here on in |
01-14-2017, 06:05 AM | #3 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Yea, hang in there OLDNTired, the effort will be worth it in the end.
01-14-2017, 11:25 PM | #4 |
Made some progress today. Was able to remove the 4 stripped screws with minimal cursing and actually had replacements on hand. Got through bag B. Have the motor/tranny and front axle and steering links done. The front diff sounds a bit off so I think I'll tear it apart before going further. It spins freely for 2/3 of a rotation and then cogs really badly. My kit only came with one spacer for the spool gear. Guessing it's the mesh with the pinion gear. |
01-16-2017, 05:41 PM | #5 |
So, I ended up powering through a few bags last night. Skipped some steps like shocks. Opted to build links last night. This morning I decided to build the shocks. I notched one of the holes and did my best to keep it clear of the e-clips. My hands weren't thanking me much after that abuse. Links and shocks are my least favorite parts of the build. Once the shocks were done I was able to start the final assembly of the axles to the chassis. I'll admit there were a few noodle scratcher moments but luckily I had my K10 there for reference on what went where. There are still a few loose ends to tie up. Body mounts, ESC and servo. Overall I enjoyed the build. I was a little surprised by the amount of errors still in the manual. If it was a persons first build I could see them getting hung up in a couple of areas. |
01-17-2017, 04:43 PM | #6 |
| Re: OnT's K5 Blazer build |
01-17-2017, 05:16 PM | #7 |
Newbie Join Date: Dec 2016 Location: Valencia
even the rtr trucks don't have the stickers installed
01-17-2017, 05:42 PM | #8 |
01-17-2017, 06:28 PM | #9 |
Thanks for the compliments guys. You can slide the stickers around some. Just don't press down really hard at first. I had to use a pair of tweezers to press down one end and get it off my finger. Position with a few tugs then wipe with the side of the tweezers. a qtip would have worked as well and not scratched up the stickers as much.
01-18-2017, 05:16 PM | #10 | ||||
| Re: OnT's K5 Blazer build Quote:
Nope, that's labor you'd have to pay for and pretty easy for end user to do. Quote:
01-23-2017, 09:44 AM | #11 |
I'm really beginning to wonder about the hardware in this kit. Had 2 more bolts strip out on me over the weekend. That makes 6 so far out of this kit. All of them were M3 25mm or 30mm. Wondering if I got a bad batch of those? Never had this many hardware issues.
01-23-2017, 10:40 AM | #12 |
Is it the drive hex on the head or the threads that are stripping out? If it's the drive head, what allen drivers are you using?
01-23-2017, 12:00 PM | #13 | |
I'll admit I'm not using the most expensive drivers out there. I have a Dynamite kit that I've had since I got my first slash back in 2012. It's been through 3 kit builds with no issues until now. This is the only kit that's giving me fits over stripping out. I've inspected the head of the driver and all the edges appear crisp. I don't see any rounding on the driver. Maybe a better set is in order. | |
01-23-2017, 12:57 PM | #14 |
I'd say a better set of drivers is in order (standard, not ball tips) RD Logics makes nice drivers and MIP. New screws going into unthreaded plastic use little CHAPSTICK on the screw threads helps the threads form in the plastic better, easier on your hands and the drive socket of the screw heads! I used to use RC motor bushing oil, now use CHAPSTICK like I learned from Ernie!!! Edited to correct Chapstick not oil on screws. Last edited by Natedog; 01-23-2017 at 11:01 PM. |
01-23-2017, 01:09 PM | #15 | |
01-23-2017, 02:07 PM | #16 |
Rock Stacker Join Date: Jan 2017 Location: United Kingdom
Looks like you've reminded me I need to strip the shocks and notch the shock pistons. Oops Need to sort that out as soon as possible. I'm heavy handed so thinking the RTR was a good idea. Gutted about the stripped hardware did you already have replacement's at the ready?
01-23-2017, 02:36 PM | #17 | |
Also hope the ESC came in today. That's the only thing keeping this thing from a test drive! | |
01-23-2017, 02:53 PM | #18 |
Ah Hobby Town USA, Only been in one store in Las Vegas when I was on holiday years ago lovely store wide range of stuff in stock. I think a little trip is need and some extra purchases maybe made lol ;) |
01-23-2017, 04:24 PM | #19 |
Unfortunately my Hobby Town is no bueno if you own a Vaterra. Ordering the screws tonight and might as well order the AE5 esc they didn't have in Stock either. |
01-23-2017, 04:50 PM | #20 | ||
Why buy AE-5, get this cheaper, waterproof, works great. https://www.hobbywingdirect.com/prod...iant=753399705 Or step up a little $42 this is way nicer. QUICRUN WP 1080 brushed ESC (2-3S) for Rock Crawler https://www.hobbywingdirect.com/coll...nt=26223842568 Last edited by Natedog; 01-23-2017 at 10:58 PM. | ||
OnT's K5 Blazer build - Similar Threads | ||||
Blazer Build | Docwolf | Kansas | 8 | 04-14-2013 09:25 AM |
1.9 K5 Blazer build | ecoli | Axial SCX-10 | 45 | 11-23-2009 09:49 AM |
K-5 Blazer build..no name yet | Mongo | 2.2 Scale Rigs | 71 | 11-05-2007 09:07 PM |
K5 Blazer Build | PaloAltoK5 | 2.2 Scale Rigs | 142 | 09-07-2007 11:32 PM |
Another 1.9 blazer build | xxizzer421xx | 1.9 Scale Rigs | 13 | 08-14-2007 10:17 PM |
