05-15-2018, 04:36 PM | #1 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Another Ascender....
Been eyeballing the Ascender for a while, and with the recent price drop I finally broke down and picked up a K5 kit (Couldn't pass it up @ $250). Probably won't be a whole lot of super cutting-edge stuff going on with this build, but I figured I'd try and document it anyways. Massive box... Containing another, much smaller, box... Sent from my SM-G930V using Tapatalk |
05-15-2018, 04:43 PM | #2 |
| Re: Another Ascender....
Box 'o parts.... LHS is finally stocking Tamiya PS paints again. Sent from my SM-G930V using Tapatalk |
05-15-2018, 07:06 PM | #3 |
Body washed/prepped for masking, and tires washed. I gotta say, these tires are better than I was expecting. From some of the other threads I read I was expecting some hot garbage, but I think these should be fairly serviceable now that the release agent is scrubbed off of them.... Sent from my SM-G930V using Tapatalk |
05-15-2018, 08:44 PM | #4 |
Transmission built / Bag A done. Not sure if I'm allowed to have an Ascender, I don't currently have a cat.... Sent from my SM-G930V using Tapatalk |
05-16-2018, 09:25 AM | #5 |
Quarry Creeper Join Date: Nov 2017 Location: Ulaanbaatar
No cat here either. Is that a good upgrade for this kit? So, this is the first I've heard about scrubbing the tires. What does that do, and what did you use please? I ordered the K5 kit this past weekend but it will be a while getting to me... -MP |
05-16-2018, 09:49 AM | #6 |
Congrats! Great truck! I'm considering picking up a second myself. I don't like the stock tires, but others have had luck with them. Good looking dog too! |
05-16-2018, 12:01 PM | #7 |
I've had great luck with the stock tires, soak them for couple days in Simple Green and water mixture, scrub clean, rinse, dry, install with Pro-Line single stage (my preference, but take a bit to break in) or dual stage foams! Cute pup! Cats are a great addition especially if you own an Ascender, but not required. |
05-16-2018, 12:58 PM | #8 |
| Re: Another Ascender.... |
05-16-2018, 01:12 PM | #9 |
05-16-2018, 01:16 PM | #10 |
Last night's stopping point... Was planning on doing some painting tonight, but the weather turned nasty again here, might be a bit damp for painting. Still need to wire up electronics, and figure out what I'm doing for wheels. Sent from my SM-G930V using Tapatalk |
05-16-2018, 01:27 PM | #11 | |
| Re: Another Ascender.... Quote:
This is not a substitute for better tires, but has helped on every tire I've used it on. If you're stuck using stock/OEM tires, this can help get you through until you can better ones... | |
05-16-2018, 01:36 PM | #12 | |
Does it seem like the Simple Green is actually affecting the properties of the rubber? | |
05-16-2018, 06:19 PM | #13 |
I've found that it gets the release off and does seem to add to the tires stickiness. I soak mine for a couple days, 5 gallon bucket with 2 gallons hot tap water, couple cups of Simple Green, add tires, stir, set lid on top to keep nasty smell and heat in better, stir around several times for couple days, (water will cool in couple hours but that's fine). After couple days, scrub them up with Dobi pad or similar, rinse and mount.
05-16-2018, 06:23 PM | #14 | ||||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
05-16-2018, 09:02 PM | #15 |
Not sure if I want to mask the weatherstripping around the windows or not. Was originally going to just do a quick/easy paint job.... It seems to be getting more complicated.... Plus I'm not real happy with how poorly the window masks match up with the edges... Sent from my SM-G930V using Tapatalk |
05-16-2018, 09:58 PM | #16 | |
05-16-2018, 10:24 PM | #17 |
Rock Stacker Join Date: Aug 2017 Location: In the woods
05-17-2018, 07:33 AM | #18 |
| Re: Another Ascender.... I've never had a body where the precut masks fit well...
05-17-2018, 08:33 AM | #19 | |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
I've become a fan of trimming the overspray film from around the weatherstripping and painting it on the outside...assuming you're painting on the inside of the body, of course. Last edited by 2mtech; 05-17-2018 at 08:35 AM. | |
05-17-2018, 11:02 AM | #20 | ||
Pro-lines are usually within shoutiing distance... These are a good 2-4mm small all the way around... Quote:
I may actually do both inside and outside. Will probably stop by my LHS on the way home from work and get some black lexan paint in a bottle (for airbrushes) and mask the stripping off and brush paint it from the inside. May also paint it with a Matte Black on the outside for a little more realistic look... | ||
Another Ascender.... - Similar Threads | ||||
Yet another Ascender | Levesque87 | Vaterra Ascender | 19 | 02-27-2016 11:59 AM |
My Ascender Built, One Bad ascender | CustomCrawlRCMike | Vaterra Ascender | 3 | 07-03-2015 03:45 PM |
New Ascender | adonis_mp | Vaterra Ascender | 5 | 03-17-2015 09:32 PM |
