12-16-2013, 02:53 PM | #201 |
Pebble Pounder Join Date: Jun 2013 Location: Morgan Hill
| Re: RolandRockshop's 2win banger KOH
Hi I really like the looks of your Rig!!!! I too just recently ordered the Derwood shock mount and am looking for some shocks. Did you have to internally limit the 90mm Kings on the front? You mentioned you used different springs as well what did you use? I see that RC4WD makes a spring kit for that shock but everywhere I look it is out of stock. thanks again for your posts & videos!!!!! |
12-16-2013, 03:33 PM | #202 | |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: RolandRockshop's 2win banger KOH Quote:
Thank you sir! No the kings were just bolted up,no limiting. Perfect fit. im using Axial Scx springs.. red and green springs Should have a running video here this week.. Some warm weather is in the forecast. | |
12-23-2013, 11:50 AM | #203 |
Vp Methods on xl sx's... |
12-28-2013, 04:19 PM | #204 |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
Siiiiick! Expensive as hell, but SICK!
12-31-2013, 07:47 AM | #205 |
| Re: RolandRockshop's 2win banger KOH Haha,you forget what hobby your in...its not cheap to begin with. Thank you,I took it out on the Christmas crawl our club had,it did extremely well. Pulled a few lines the scx‘s couldn't. The swaybar helps a ton on the rocks. |
01-02-2014, 01:43 PM | #206 |
Do the VP caster block and knuckles add improvements or just durability ?
01-03-2014, 01:16 PM | #207 |
increased size 11mm exterior Bearing. The DD steering helped more than anything.. The alum holds those kingpin set screws better for sure. Nice tight fit as usual.. |
01-03-2014, 11:31 PM | #208 |
My DD steering kit sucked. I have a TON of slop in it. Daren's aware of it, but really wish it fit right. Glad yours worked out!
02-16-2014, 12:24 PM | #209 |
at our Arcc Rally in the valley G6... waitin on szczerba to MOVE OUT THE WAY!! |
02-16-2014, 03:41 PM | #210 |
Pebble Pounder Join Date: Jul 2013 Location: SoCal
| Re: RolandRockshop's 2win banger KOH |
04-01-2014, 06:50 AM | #211 |
04-01-2014, 06:55 AM | #212 |
at the U4RC races.. a few pics I got of scotty driving the twin banger.. |
04-03-2014, 01:08 AM | #213 |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
What about the new axle housing from RC4WD. Sent from my DROID BIONIC using Tapatalk |
01-08-2017, 12:55 AM | #214 |
Newbie Join Date: Jun 2016 Location: Mckees Rocks (Pittsburgh)
For the Currie axle install does anything else need to be done to front end other then reversing the front diff and trimming the tab Only stuff needed to order is: the Currie axle AX30421 SCX10 Rear Straight Axle SHAFT AXA1230 & AXA1221 Bearings AX30395 HD Bevel Gear Set 38T/13T |
RolandRockshop's 2win banger KOH - Similar Threads | ||||
RolandRockshop's Monsta Truck build | ROLANDROCKSHOP | Mega/Monster Trucks | 73 | 08-29-2015 08:02 AM |
flathead 4 banger | jetboat | 1:1 Full Size Vehicles | 17 | 11-12-2012 05:14 AM |
Rc KOH | crawladan | Chit Chat | 7 | 04-13-2009 01:53 PM |
