02-20-2013, 04:30 PM | #1 |
Sr. Product Developer Join Date: May 2005 Location: Fontana
| Grease in the transmission?
No, doesn't need it. We are using the same material that we have developed for the TLR racing transmissions of which we never add any grease or lubricant. Will it hurt if you do? No not really but any dirt or dust that does find it's way into the transmission case will stick to the gears when they have grease on them. I just wanted to clear this up. Thanks, |
02-20-2013, 04:34 PM | #2 |
Quarry Creeper Join Date: Jan 2010 Location: Lunenburg
Interesting. Just loaded mine up with Lucas Red & Tacky.
02-20-2013, 04:39 PM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: Hiding the bodies
| Re: Grease in the transmission?
It may have been designed for no lube, but mine is quieter and shifts better with some red n tacky in it. Thanks for the inside info though. Nice to know it wasn't an oversight at the factory.
02-20-2013, 04:40 PM | #4 |
Awesome. Too lazy to dismantle mine right now anyways.
02-20-2013, 04:46 PM | #5 |
Quarry Creeper Join Date: Nov 2007 Location: WNC
I greased mine although not excessively. I gotta pull it again tomorrow night for a motor esc swap anyways. I will probably get any excess grease out of there but not all of it. I just don't feel comfortable running bone dry gears.
02-20-2013, 05:01 PM | #6 |
Pebble Pounder Join Date: Jan 2012 Location: Locust Hill
Yeah, mine didn't even work dry. Wouldn't shift, noisy as hell...I'll take my chances with the grease...
02-20-2013, 05:19 PM | #7 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Yeh for me unless modified for crawling 100% they are essentially a short course truck and you wouldn't dream of adding resistance into the train with gobs of grease with say an sc10. I have greased mine, as its going to be a crawler and it all helps the drag breaking. |
08-18-2014, 01:56 PM | #8 |
Rock Stacker Join Date: May 2014 Location: vancover island Canada
so i've upgraded to the metal transmission gear from Vaterra should I use some grease? if so what type would be best? all I do is crawling and trailing! Thanks
08-18-2014, 04:20 PM | #9 |
Rock Stacker Join Date: May 2011 Location: Manchester, NH
The kit has metal gears and came with instructions to use the losi high pressure black grease ( TLR77000 ) included.
08-19-2014, 01:40 AM | #10 |
RCC Addict Join Date: May 2012 Location: The Volunteer State
08-19-2014, 01:22 PM | #11 |
Quarry Creeper Join Date: Dec 2012 Location: SoCal
wow. when my TH was new, It could barely be shifted (by hand, forget the junk servo) I disassembled the trans, lightly greased everything and it's worked great ever since
Grease in the transmission? - Similar Threads | ||||
Axle grease, grease gun idea. | arctichorse | Axial SCX-10 | 1 | 11-14-2012 11:52 PM |
To grease or not to grease?...... that is my question | 1111Mavrick | Axial Wraith | 10 | 02-08-2012 06:05 AM |
transmission gear grease? | turbobladz | Axial XR10 | 8 | 01-16-2011 11:00 AM |
