03-12-2013, 06:11 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| gear ratios?
i have a associated reedy 3300kv motor in my hammers. i started with stock gearing and it was to slow, went to 30/78 better but motor is about 109*. im going to try 32/78 but this looks like alot of gear. its almost to spurs, lol. what you guys running for gearing that are looking for more speed? |
03-12-2013, 06:16 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: gear ratios?
Volt up, gear down....
03-12-2013, 06:25 PM | #3 |
| Re: gear ratios? |
03-12-2013, 08:10 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Re: gear ratios?
4s.
03-14-2013, 07:47 PM | #5 |
Newbie Join Date: Jan 2011 Location: Englewood
| Re: gear ratios?
what would you guys use on a 3s 13.5 ballistic, gearing wise?
03-15-2013, 09:50 AM | #6 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
| Re: gear ratios?
2 questions regarding gearing.... 1 - whats the stock ratio (48p) 2 - whats a comparable 32p ratio to stock? (almost identical please) ....thanks. |
03-15-2013, 10:19 AM | #7 |
| Re: gear ratios?
28/78 is stock gearing or 2.7857 ratio just replace numbers with 32 pitch to get same ratio example, 20/56 yields 2.800 ratio, you wont always get exact depending on what spurs are available. |
03-15-2013, 10:47 AM | #8 |
| Re: gear ratios? |
03-15-2013, 03:27 PM | #9 |
Pebble Pounder Join Date: Jan 2013 Location: San Diego
I've been running 32p 51t and 14-18t I don't have a heat gun, but 18t doesn't seem to get too hot. I can always touch it. I might try 20t as well. |
03-15-2013, 04:58 PM | #10 |
| Re: gear ratios?
with my reedy 3300kv i ended up going 32/78. seems pretty good.
03-15-2013, 06:42 PM | #11 |
Rock Crawler Join Date: Feb 2010 Location: eugene
| Re: gear ratios? |
gear ratios? - Similar Threads | ||||
gear ratios?? | too many hobbies | Losi Micro-Rock Crawler | 4 | 08-01-2010 10:18 AM |
Gear Ratios | losikid | General Crawlers | 21 | 01-02-2010 04:55 PM |
R1 gear ratios? | HULK | General Crawlers | 1 | 10-10-2007 11:41 AM |
gear ratios | jhtoy | General Crawlers | 3 | 01-10-2007 04:37 AM |
gear ratios | eric113 | Traxxas Crawlers | 9 | 12-01-2005 11:58 PM |
