Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Vaterra Scale Rock Crawlers > Vaterra Twin Hammers
Thread: Rock Racer or Crawler
Old 03-19-2013, 06:12 PM   #1
Default Rock Racer or Crawler
It seems this car is is better suited for speed and not crawling. I can't decide how I really want to set mine up. I like running trails and crawling more than speed runs (mainly because I have no one to run with or a descent place to really run it as a rock racer).
What is everyone doing with theirs, crawling or rock racing ?
aceisback is offline   Reply With Quote
Old 03-19-2013, 06:32 PM   #2
Default Re: Rock Racer or Crawler
Im setting mine up for crawling, fully locked, 3s, 13.5, mmp and currently redoing the front suspension to make it articulate more. but it can still do speed runs, its just a handful lol
lazynocturnal is offline   Reply With Quote
Old 03-19-2013, 06:42 PM   #3
I'm setting mine up as a go fast runner. Took mine out to Irvine Lake RC track this weekend and it didn't do half bad on the 1/10th scale track. I have to admit this little buggy is a lot of fun.
Chris
Baja Bandido is offline   Reply With Quote
Old 03-19-2013, 07:16 PM   #4
I'm at the same impass..
Wishing the trans had a bigger gap between the 2 speeds..
I'm running a 17.5t with lower gearing for crawl spots..
Too hot of a motor makes this rig a fast desert racer and a faster desert racer...
elsewhere is offline   Reply With Quote
Old 03-20-2013, 05:11 AM   #5
Mines more a trail/basher, 9.5T and SV2.
Fast and fun.
vipxj is offline   Reply With Quote
Old 03-20-2013, 08:20 AM   #6
Sounds to me you should have done what my friend did. He got a wraith and added the 2 speed trans to it. Now he can crawl much better than the TH ever can plus has some speed to bash. Me, I have a dedicated crawler and now the TH to go rock racer style on the trails.
catzuk is offline   Reply With Quote
Old 03-20-2013, 09:06 AM   #7
I chose fast. Here are the pros and cobs I noticed:
Fast cons:
Steering is sloppy. Way too much play. I can't wait for a fix for this.
Body roll: the heaviest sway bars help a bit.
Rear axle: not ideal for speed. Having the rear locked is also not ideal for high speeds.
Slow Cons:
Front suspension will never full articulate on its own. I backed off the rocker nut, set coils softer and locked the front. It helped, but its just the nature of ifs with no weight over it.
After having a wraith, trying to make this a crawler just didn't make sense to me.
I think the TH is an excellent basher. That is its string suit. It can take a hit. It can go pretty fast, and it can get out of trouble.
Sethmetal is offline   Reply With Quote
Old 03-20-2013, 09:13 AM   #8
Fast cons:
wrong.. if a locker is not ideal for speed why does every race car out there 1:1 scale have a locker in it??
its to put the power to the ground evenly throughout both tires,,
locker in rear end = perfect for high speed runs, just takes knowing how to drive,,
JDCrawler27 is offline   Reply With Quote
Old 03-20-2013, 06:42 PM   #9
Sorry but working in a high performance SCCA based race shop for years we NEVER did locked rear drive vehicles, ltd slip or torque bias was it.
The only cars that got spool treatment were front drivers oddly enough..
A drag car may be different..
The TH is fun but with MIP not being able to work out the bugs in the front end I can see mine going up for sale sooner than later...
Old 03-20-2013, 09:00 PM   #10
^ what he said.
Both my 1:1 4Runner and Twin Hammers jerk to the side under hard acceleration. This throws the TH off course more than my 4Runner because of the slip steering.
Also, in corners the locked rear acts as a corkscrew and causes the rear to slip out.
Furthermore, a locker is quite different than a spool, which is really what the twin hammers has. A real locker acts as a differential when coasting or cornering.
Old 03-20-2013, 09:33 PM   #11
Almost all go fast KOH type of cars have some type of arb locking rear diff, best of both worlds. Locked up like spool for crawling and then unlocked like open for high speed handling.
BIGJOEDUCKSLAYE is offline   Reply With Quote
Old 03-21-2013, 12:26 AM   #12
All Good ideas,
They should outlaw cars with dual personalities. Too much strain on the brain trying to decide .
I think am looking at a Holmes setup with the 27T motor as I have pretty much decided that I don't need the all out speed, but I want to do more trail driving with this. Need to get lockers for mine next I guess, and see how it does. I have a Losi Nightcrawler and an Axial Honcho, so I am not totally requiring the TH to be a dedicated crawler at this time.
Old 03-21-2013, 01:04 AM   #13
Drop in a 4.5....Now its a wheely poppin 35 mph daily driver...!!
scottanthony is offline   Reply With Quote
Old 03-21-2013, 09:18 AM   #14
Big Mike's Avatar
I've been having a blast with this thing, but now I'm starting to get picky.
And that is the first glaring drawback to the TH - it's a handful at speed, and
I'm thinking 80% of that is excessive play in the steering linkage. Now that the "new" is wearing off that's the first thing I'm going to look at I think...
Big Mike is offline   Reply With Quote
Rock Racer or Crawler - Similar Threads
Rock Racer vs Crawler klamp Newbie General 7 06-22-2011 12:37 PM
Rock Racer to Rock Crawler Conversion Orgnoi1 Axial AX-10 Scorpion 9 03-06-2010 10:07 PM
Axial Crawler Rock Racer Nicklovin General Crawlers 2 03-02-2010 09:45 PM
