03-29-2013, 11:35 AM | #1 |
Rock Stacker Join Date: Mar 2013 Location: USA
| Front Differential
So the completely open front diff is quite annoying and useless. Well I had everything torn down and got to thinking; what will allow for slow spinning, but lock when needed if spun too fast? So I mixed up some corn starch and (tap) water (distilled would probably be best) cleaned out the housing and filled her up. This seems to work quite well. But I have no run time on this and will report back with results when everything is put back together (brushless on 3s .) |
03-29-2013, 12:09 PM | #2 |
| Re: Front Differential
Head out of the kitchen and grab some silicone diff fluid, tried and true it is.
03-29-2013, 12:12 PM | #3 |
Haha, but the way this works it essentially becomes "locked" when either front wheel spins freely after loosing its grip. Plus it was a free little experiment. |
03-29-2013, 12:12 PM | #4 |
RCC Addict Join Date: May 2011 Location: Utah County
Silly putty Sent from my SCH-I535 using Tapatalk 2 |
03-29-2013, 12:19 PM | #5 |
Newbie Join Date: Mar 2013 Location: Fort Collins
I want to keep mine a Rock Racer (crawl, jump, bash, etc..) For this purpose: Diff fluid (not super thick) would be better and have a longer life than silly putty (very thick and specifically for crawling). Right? |
03-29-2013, 12:34 PM | #6 |
Lockers are specifically for rock crawling. Sent from my SCH-I535 using Tapatalk 2 |
03-29-2013, 12:34 PM | #7 |
Just leave it open if it's a basher.. Sent from my SCH-I535 using Tapatalk 2 |
03-29-2013, 12:51 PM | #8 | |
| Re: Front Differential Quote:
True, but you know what I mean. In my case the silly putty probably wouldn't be ideal because I will be doing more than just crawling. I guess you're right about leaving it open for now and not bothering with diff fluid.. | |
03-29-2013, 09:27 PM | #9 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Won't your little mixer put moisture in the diff and create rust!!!
03-29-2013, 09:49 PM | #10 |
| Re: Front Differential |
03-29-2013, 11:10 PM | #11 |
Rock Crawler Join Date: Oct 2011 Location: minot
I'm using silly putty currently with great results... It's weaker than a locker so the axles won't just sheer, but Allows for a little diff action under cornering.. I'm sure 1,000,000wt silicone is the ticket but the putty worked in a pinch. |
03-30-2013, 09:09 PM | #12 |
Newbie Join Date: Sep 2005 Location: mooresville
After cleaning out my front case, I filled my front diff with 20,000wt oil. I will be doing high speed and crawling. I think I'm gonna change it out to 30,000wt. It's not slow enough for me for crawling. just my 2 cents. later.
03-31-2013, 10:40 AM | #13 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i have some 120,000wt diff oil from my savage that im going to use and thinking i might swap out the stock stuff for the velineon system out of my slash and put the twin stuff in my slash.
03-31-2013, 05:06 PM | #14 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Cornstarch and water is a great idea actually, when you attempt to move through it slow it will allow for it and when you try and move through it fast, it firms up.... See mythbusters: walking on water. The cornstarch is made up of long chains of atoms - a polymer. These chains can move past each other, but they take some time to do this. If you pour it slowly, it can flow like a liquid. If you try to force things and make the chains slide more quickly than they want to, they get entangled - and the mixture gets firmer. So if you push hard on it, it acts more like a solid. |
03-31-2013, 05:47 PM | #15 | |
RCC Addict Join Date: Jan 2010 Location: Vermont
04-01-2013, 09:57 AM | #16 |
Quarry Creeper Join Date: Sep 2008 Location: Rogue River
I used silicone in mine, Works great and will give under pressure |
04-01-2013, 10:01 AM | #17 |
Rock Stacker Join Date: Dec 2011 Location: Orange County
Sorry for hijacking but what diff oil are you running when you install the optional front locker?
04-01-2013, 10:24 AM | #18 | |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
You either run diff oil or the locker, not both together. The locker locks it, no diff action between front wheels. By using various grades of oil you can change the amount of give between front wheels with oil used. | |
04-01-2013, 01:26 PM | #19 |
04-01-2013, 07:04 PM | #20 |
Ha ha ha thanks for busting a noobs chops.
Front Differential - Similar Threads | ||||
differential | mitchr97 | Axial SCX-10 | 11 | 03-04-2013 02:29 PM |
differential | mitchr97 | Axial SCX-10 | 1 | 10-31-2012 01:37 AM |
Differential in front axle? | Jay-Em | Axial Wraith | 6 | 09-27-2011 01:49 PM |
Is this the differential for the WK?? | GUERO4X4 | HPI Wheely King | 7 | 06-29-2007 04:46 AM |
