11-19-2013, 10:47 PM | #1 |
Newbie Join Date: Nov 2013 Location: Los Angeles
| Transmission issue
So i have a problem. My drive shaft doesn't soon unless i move the shift servo into a sweet spot. If i take it out of that specific position then the drive shaft locks up. Anyway to fix this? Honestly i rather just make it into a one speed transmission but i don't know how to do that either |
11-21-2013, 06:52 AM | #2 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Transmission issue
take tranny apart and inspect... ive seen others swap in a Axial tranny instead of using the 2spd. |
11-21-2013, 08:00 AM | #3 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
I'm swapping mine for a scx10 tranny.
11-21-2013, 10:14 AM | #4 |
Rock Crawler Join Date: May 2013 Location: Rancho Cucamonga
I'd suggest that once you find that "sweet spot", leave it in 1st gear and unplug the servo from the rx. Then you can't shift.
11-21-2013, 03:07 PM | #5 |
I took it apart and it looks fine, but this is my first vth so I'm not sure how it should look. I will look into doing the swap or unplugging it. |
Transmission issue - Similar Threads | ||||
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
R3 transmission issue | creator_hun | RC4WD Trail Finder 2 | 0 | 07-24-2012 12:36 AM |
