Re: Wheelbyte's Twin Hammers I'm excited on how this came out, it's inspired me to build mine |
Re: Wheelbyte's Twin Hammers How did you mount the radiator? |
Re: Wheelbyte's Twin Hammers Quote:
Re: Wheelbyte's Twin Hammers I bought the exo light bar and radiator, just trying to figure out how to mount then both |
Re: Wheelbyte's Twin Hammers Wheelbyte, I love your TH. I have got a lot of inspiration for my own build from yours. One random question though, where did you get the scale decals on the side panels? I know the King and Mickey Thompson came with the products, but the Monster Energy and GoPro decals especially look good. Where did you get these? Thanks. |
Re: Wheelbyte's Twin Hammers Wheelbyte I wish I had a park near my house like that. There is really no place like that close to me. Nice.... |
Hi thanks!!!! I ended up making the decals..... even the King ones. I happen to run a digital press at my work so I picked the logos I liked resized and printed on 2 mil clear poly. I found that if you laminate with clear packing tape over the top they are really rugged and scratch resistant. If you PM me your address, I have a few left over I'll drop them in the mail. Greg |
Re: Wheelbyte's Twin Hammers Question...What weight oil are you running in those Kings and Ultimate Shocks on the rear. I have worked with the ones I have and just can't get them working the way I would like. I have a set of Proline/axial shock on the rear right now. Try'n to get that scale look but just don't like the way they look but they work great. |
100# wt in the Kings.... yep I did say 100 HaHa.....any heavier I thought I was gonna have to start using a lightweight or blended diff fluid in them. I also changed one of the springs out but I cant remember exactly what I went to will have to look when I get home. 20# wt in the Ultimate Shocks and I have the springs removed and am running them as dampners only. I have the setup pretty close to where I like it now..... I was in the same boat as you before I had Proline Powerstrokes on it which are easy to tune but lack the scale look that I was going for. |
Re: Wheelbyte's Twin Hammers Thanks. I have not tried any quit that heavy. I think 80 was high as I have gone. |
Re: Wheelbyte's Twin Hammers I'd love some stickers, I mean who doesn't haha |
Re: Wheelbyte's Twin Hammers Wheelbyte, I noticed you are running the Bluemonkey RC lower links. Did you notice on their website they just changed the design. I am torn between the BMRC and the Vanquish links. The BMRC links new design looks very similar to the Vanquish links now, except the ends are different. How do you like yours? |
I really like the scale appearance of the Vanquish links.... the "New" BMRC links also look great.... hopefully someone will get a set and let us know how they work with the King Shocks. |
Re: Wheelbyte's Twin Hammers So I replaced the stock foams that came with the RC4WD 4.19 Mickey Thompson Baja Claws with the Crawler Innovations Deuce's Wild Single Stage Closed Cell foams. Have not had it out on the rocks yet but there is a huge improvement in handling at speed now. http://www.wheelbyte.com/b_board/TH29.jpg |
Re: Wheelbyte's Twin Hammers You will have to keep us updated on those new foams |
Re: Wheelbyte's Twin Hammers still the best looking hammers ever wheely !! |
Re: Wheelbyte's Twin Hammers New Crawler Innovation foams are working out great... perform really good on both the rocks and at speed. I am stoked they are also water proof compared to the stock foams! I ended up swapping out the Derwood steering kit in my TH with the Irie kit which uses ball bearings instead of bushings. It removed tons of play out of the front end and the fit and finish is excellent. I continue to run the Derwood front shock mount and I really like that piece and it works without a problem with the Irie Kit.... bolts right up just like it did on the DD kit. http://www.wheelbyte.com/b_board/TH30.jpg http://www.wheelbyte.com/b_board/TH31.jpg Irie's kit is on the top Derwoods is on the bottom http://www.wheelbyte.com/b_board/TH32.jpg http://www.wheelbyte.com/b_board/TH33.jpg http://www.wheelbyte.com/b_board/TH34.jpg http://www.wheelbyte.com/b_board/TH35.jpg |
Great pics my friend. I also have the Derwood kit and have been working on adding a custon upright shock mounting system. This is what ive got so far. My only problem is the springs in the Rc4wd Ultimate scale shocks are not strong emough to support the rigs weight. I haven't had much luck finding any stiffer springs that will fit them. Any suggestions ? http://img.tapatalk.com/d/14/05/20/hesepase.jpg |
Re: Wheelbyte's Twin Hammers It looks to me you could even use the other two tapped holes that are for my shock tower if you drilled them in the DD tower. Correct me if I am wrong. The reason I say something is on one of my prototypes I was able to pull out the two screws that go into the diff housing, which is why I added the other two tapped holes. |
Re: Wheelbyte's Twin Hammers Beautiful build! |
